Can thermocouple device be repaired - Heating & Cooling
    Top Expert:
  • Heating & Co... Master
  • 14,512 Answers
No and if tried the repair would cost more than the replacement
Posted on Apr 26, 2017
Try to lite pilot lite, hold down 5 mins, when let up pilot goes out. What's wrong
Sounds like a bad thermocouple. You bypass the thermocouple holding the button down and allow the thermocouple to heat up which in turn signals your system to allow for gas to continue flowing. It's a safety device to shut off gas flow in event your pilot light is unintentionally blown out. They are typically a simple fix to replace however there's no mention of what appliance you are attempting to light so my recommendation is to contact the appropriate service technician and have the do the repair for you. Thermocouples are typically inexpensive parts.
Jan 12, 2018 | Cars & Trucks
Need assistance in repairing a 1995 Jayco Eagle 1207KB hot water heater. The pilot will not remain lit. Stays on a minute then goes out.
next to the pilot light is a iron rod. this is a safty device called a thermocouple.
1. it could be covered with black carbon and just need a clean.
2. the pilot light jet needs a clean to make a bigger flame as the thermocouple is not getting enough heat.
3. the thermocouple is burnt out and needs replacing. it should be smooth all over.
Jun 30, 2017 | Water Water Heaters
My oven isnot working, no gas and no ignition. how do i fix this
Tip & How-To about Ovens, Furnaces & Boilers
Pilot Light won't stay lit?
We get asked this question many times.
If you light your pilot light, hold in the button and then when you release it and the pilot light goes out, generally you need a new thermocouple. Gas repairs can only be undertaken by a qualified gas technician so you can't do this job yourself.
The thermocouple is a safety device that recognises that the pilot has a good flame and is enough to ignite the main burners. The thermocouple open that valve to the burner.
In limited circumstances the thermocouple doesn't need replacing, either the shield that aims the flame to the thermocouple has become dislodged, or the pilot jet is a little blocked by debris. Either way, having the appliance serviced by a qualified gas fitter is the way to go. I am sure you will have seen news stories about explosions caused by gas leaks and faulty appliances.
Posted by Andrew... on Jan 17, 2016
May 01, 2016 | Amana Kitchen Ranges
Pilot will light but won't stay ON
Jan 27, 2016 | Heating & Cooling
Where is a gas fuse in a Kenmore oven?
Gas ovens don't have a fuse. Won't the oven light?
Jan 26, 2016 | Kenmore Ovens
Will not ignite. Could this be due to a bad thermocouple?
Jan 22, 2016 | Heating & Cooling
Why won't the pilot stay lit? I've seen where a bunch of people have asked and received no reply.
I have answered this question many times.
Jan 16, 2016 | Heating & Cooling
My reddy 30 heater will not stay lit after starting, I have held the switch down for longer than 30 sec, but it just want stay lit
The thermocouple is what tells the gas valve to supply or not supply gas. Several things can cause the thermocouple to malfuntion.
1. pilot light jet is clogged and will not allow the pilot light to reach and heat the thermocouple. Repair by cleaning the pilot light jet out.
2. corrosion on the thermocouple which will also not allow the flame from the pilot to heat the thermocouple properly. Repair by sanding the thermocouple lightly with sandpaper
3. Thermocouple is bad and needs replacement.
Mar 25, 2010 | Heating & Cooling
What component inline with thermocouple on assy 9003542:
The thermocouple connects directly to the gas valve. They're universal fit.
Oct 22, 2009 | Reliance Water Heater #9003531 NAT Gas...
Won't dry
Intermittant coils. Seen it. Some repair PIX
Sep 09, 2009 | Dryers
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
