Question about In Microwave Ovens
In my microwave oven model C103FL, how to confirm that touch panel has gone bad? Can it be a problem with the PCB to which it is connected?
MicrowaveSvc
  • 9098 Answers
SOURCE: Samsung Bio Ceramic Microwave lamp fused.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
You can order specific Samsung parts here.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Nov 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool Microwave Hood combination Model
Direct spraying of cleaners on the keypad and steam from the cooktop can short the keypad.
Luckily, it dried out. Sometimes it doesn't, and the keypad has to be replaced.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
Posted on Jun 24, 2009
  • 1531 Answers
SOURCE: Kenmore Microwave Oven, Model#66568680891
you should change the touch panel and or the control module.check to make sure the power supplied is correct and all connections to the board are all secure.
Posted on Feb 24, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: I have sharp microwave oven
First I would suggest a "hard reset". Simply unplug the oven for a minute or two, then try again.
If it still fails, it may be that the keypad has failed, or there is a bad connection due to moisture, grease, etc.
This is an Australian model, so it's hard for me to give more specific information.
But one some US models the LCD and keypad connect to the circuit board via a rubber "zebra strip" and losing that connection can result in a loss of display segments and / or key response.
I've attached a diagram showing where one can clean to restore operation in this case.
Posted on Oct 02, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Montgomery Ward "Household Microwave
Hi and welcome to FixYa. I am Kelly.
The Repair Clinic has parts for your Montgomery Wards Microwave but, they are NOT listed on the website. Call them with your model number and they can look it up: Make sure to tell them it is a mechanical clock timer.
  • 1-800-269-2609, 8 am to midnight ET, 7 days (Repair Clinic)
  • And...... if you can find a number on the actual timer assy other than the timer motor, there are still many of these mechanical timers out there deep in the parts supply shelves. I would bet your could still find this timer pretty close to home in a local Appliance repair shop.
    Just a note on older appliance parts (+25 years) .... sometimes the cost of replacement parts is far more than the unit cost new.
    Thanks for choosing FixYa.
    Kelly
    Posted on Oct 16, 2010
    Start button is not working.
    • Check for bad interlock switch or interlocks that are not being properly activated.
    • confirm that the START touch pad button is not itself faulty.
    • If it is not a touch pad unit, check the controller-it is either not sensing the start command or there maybe some other reason, like an internal blown fuse
    • Check that there are no missing power supply voltages for the controller or any bad connections.
    • If your a DIYer, obtain a repair and service manual for you particular model microwave; or else bring it to a qualified technician in microwave repair. You'll want an estimate for diagnostic fees, parts and labor.
    • See if the technician is willing to apply the diagnostic fee toward the repair costs for price reduction.
    • If the bill to repair the microwave is 50% more than what it would cost to buy a new one, deep six the old one and splurge on yourself and family for a new microwave oven...you deserve it! :)
    Mar 24, 2015 | Microwave Ovens
    Microwave gone dead 2nd time
    thats easy - ITS WARRANTY - take it back -
    Nov 28, 2013 | Microwave Ovens
    We have a Dacor Microwave DMT2420S that everything works except the Touch Screen doesn't light up.
    The display board is bad, it may be part of the control PCB or it may be separate. Some are back lit and some are lit internally.
    Oct 21, 2013 | Dacor DMT2420S Preference 24" Microwave...
    F3 code
    An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
    On many models of microwave oven means a problem with the touch panel, (tact switches).
    Replace the switch panel to fix the fault.
    Hope this helps.
    Aug 10, 2011 | General Electric Microwave Oven
    My TAPPAN Microwave Oven Model Type: TM5430 B only shows S1 in the display and it doesen't react if i push any othetr buttons. What can i do ???
    Unplug the unit, let it sit for a minute to clear power from the control board then plug it back in. If the display still shows S1, that could indicate a bad touch switch on the front panel, a bad connection between the touch panel and the control or a failure in the control. Unless you can get parts cheap and fix it your self, it's not worth paying for the repair.
    Jul 08, 2011 | Tappan Microwave Ovens
    Keypad is not working
    Remove top cover and than front panel from the microwave,remove the PCB(printed circuit board) and the PCB and the connection strip connecting PCB with panel,problems are generally seen due to moisture deposit or deposit of small insects due to the dampness,if the problem remains after cleaning then finally replace panel itself.
    Feb 07, 2011 | GE HVM1540SNSS Microwave Oven
    I have sharp microwave oven model R-231F. On digital display (which is suppose to show time) only 88888 is displayed. suspect fault with the PCB behind display or keypad. Please advise how I can obtain...
    Oct 01, 2010 | Sharp R-1480 Microwave Oven
    Feb 24, 2010 | Microwave Ovens
    Keypad on ge spacemaker microwave oven not working
    Needs a new touch pad if it doesnt respond, you can check the connection between the touch pad and the pcb, but it sounds like there is an O/C on the pad.
    May 18, 2009 | GE Microwave Ovens
    High voltage surge
    We regularly repair these GE / Samsung boards from customers nationwide with just such problems for $32.50. If it's too bad off, we can get this board (# WB27X10466 remanufactured) for $145. A new board runs about $180. We would need the full model number with suffix.
    Sep 04, 2006 | GE JVM1490 Convection/Microwave Oven
    Microwave Ovens Logo
    27 people viewed this question
    Top In Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    vince
    Are you an In Microwave Oven Expert? Answer questions, earn points and help others
