Where do i have to press in the remote when my DVD don't play bt write demo on the screen??
Sony music hi fi system mhc-gzr88d show only demo not started
If only demo mode is playing,it's mean set is in standby mode.Normally
in standby mode it can't be operated.You have to power on the set by pressing power botton during demo mode.Once it gets power on,it will
start to work according to user required function.If the set not get power on after pressing power botton,then it's an electrical problem
and need to visit your nearby repairing centre.
Oct 17, 2012 | Sony MHC-GZR88D USB MINI DVD HI-FI SYSTEM...
How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
Oct 20, 2011 | Toshiba DVR670 Player
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
The brand name Samsung is in the middle of the screen. I wish to remove it and with no manual I do not know what to do. Also there are other messages fliping on and off the screen too.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
  1. Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
  2. With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
    Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
  1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
  1. Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
  2. Press the MENU button.
  3. Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
    Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
  1. The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
  2. Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
  1. Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
  2. Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
Feb 01, 2011 | Samsung TXD1972 19" TV
PS2 will not play DVDs
hEy i hAd the sAme pRob...............dOn wOrRy all u hAv to do is to turn on uR pS2 witthout puttin a DVD oR aNy diSc........on mEnu screen gOto [options] by pRessing 'triangle' button......... a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst.....then insert the DVD movie........tURn off PS2....press n hold the reset button till the blue light is turned on......release the button and press it again.............. it wOuld take a little tYm foR uR DVD movie to be loAded........be patient till the movie plays it self..............
Jun 13, 2009 | Sony PlayStation 2 (PS2) Console
Dvd dose not play
1. Insert any disc
2. Press Eject on remote (Once you eject, don’t pull the disc out)
3. Press DVD Setup on remote
4. Press 8800 on remote
5. Press DVD Setup on remote
6. Press Angle on remote
7. Region code number (0 : free, 1 : USA, 2: Europe)
8. Press (Skip Fwd) on remote.
Apr 20, 2008 | Blaupunkt IVOD-1022 Overhead LCD Monitor...
Dvd player stuck in 'demo repeat mode'
If pressing the stop button on the unit doesn't work, try unplugging the unit for a few mintues, plug it back in, then press and hold the stop button again, that always work.
I agree that this is not the most superior device on the market and sound is average, but it has many advantages that others just don't offer - small size, no complicated cables, unbeatable price and has a very nice appearance, makes all other look like dinosaurs. Untill all others catch up with that, I'm keep this...
Apr 10, 2008 | LG LFD790 System
Stuck on DEMO Mode
Just try to initialize THE plager again. Without cd in the player switch on the power while pressing the Play, Open and Next Track button. On the display it says " initialized" Ready. Frits van Heekesen Nijmegen The Netherlands
Dec 27, 2007 | Denon DVD-2200 DVD Player
press and hold the power button for about 5 seconds to reset the player
Aug 13, 2007 | LG DN798
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
