Question about Toys
Eazi copter tx juice will not start - Toys
Tip
Infrared RC Copters
Hi, everyone.
Ever since I saw the first advertisements on YouTube, some years ago, I wanted to acquire one of these little helis. When I finally acquired one, I had lots of fun until the little thing started to give me trouble.I own several of these mini-copters and have managed to maintan most of them in good working conditions for about 4 years now.
I would like to share some things that I have learned about RC Infrared Helis, specifically speaking, the airhogs RC helicopters.
First of all these little copters are not intended to be used outside home unless on a very calm day and on an area that has to be protected against sunlight, because sunrays interfere enormously with the IR beam with which the Infra-red light-emmiting controller communicates with the copter. I have found out that even while flying an air hogs copter indoors, when you get them close to a ray of sun shinning through a window, it suddenly drops to the ground.
Next, Most problems that I have encountered have to do with a combination of low battery power, plus trimming. In some of these copters, trimming can take a great deal of pulses before you can get them to fly right.
On the first models I would cut a cardboard fin and tape it to the front of the heli, below the nose and across form it, side to side to make it thrust forward.
Many times there were things like hairs or pieces of cobwebs attached to the axle of the back rotor, causing the heli to spin uncontrollably, even after trying to trimming it with the remote contol.
On other ocassions the copter wouldn't hold a charge even with fresh batteries on the controller. I learned that in time, the charger connector/plug may get dirty, so I usually spray the inner part of these connectors with a light coat of contact cleaner(available at any electronics store like Radio Shack) and then plug and unplug the connector a few times. This has worked fine with my older copters that have presented such problems.
on Sep 26, 2011 | Silverlit Toys Red Air Hogs R/C Havoc Heli...
RC helicopter no longer responds to controller
1st,
extend the antenna out. (unwrap from skids ) and wrap it to the tail fin and back.
Also check the connection to the RX pc board. May need to be soldered better.
These are 23mhz,72mhz radios and Binding (which is a 2.4ghz digital system) is not going to happen here.
What to look for is the led on the heli rx. Turn tx on first, then heli. Look at led. It will blink at first then go solid when it syncs to the TX signal.
The heli should have the channel sticker on it (look at rx also) this needs to match the tx (some tx have a channel selector 1,2,3- a,b,c).
Jan 12, 2014 | Toys
Air Hog Pocket Copter won't charge
If this was the original charger for the air hog copter and it just started to fail in recharging , there must be a faulty part inside the charger that is causing the problem, staying red light during charging period and never turns to green or other color to show that it was charged is one problem but when it also shuts off after 30 seconds without charging definitely shows a faulty part or parts inside the charger. To check this out you can try another good charger which you can borrow from a friend to see if it would charge your copter or you can take it to the store where you bought the copter , they may be able to confirm the fault on your charger, if it can be fixed or needs a replacement.
Dec 27, 2013 | Spin Master 1001130 Air Hogs R/C Pocket...
Nemisis battle copters on same channel
I just fixed this problem on mine. The helicopters are not actually set on channel A. Not sure why it says that on the bottom. They match the channel on the controller.
Here is how:
-First turn one helicopter on
-On one of the controllers select channel "C"
-Move the throttle stick(on left) all the way down
-Turn the controller on
-Move the throttle stick all the way up and then back down again
-When the light goes from blinking green to solid green that copter is ready
-Repeat this with the other copter but select channel "B" or "A" instead
For some reason it works better when you start with the higher channel, C, first and then work your way down.
Hope this helps!
Jan 08, 2013 | Toys
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
I have a nano copter blaster 3D. I have put new batteries in the remote control. When i switch the remot on I get a red light and nothing else happens. It was bought for some friends who returned it...
You have to charge the copter first. Open the cover on the remote control and plug the little cord into the bottom of the copter. Make sure the copter is turned off. Switch on the remote and you will get a green light which means it's charging. When it goes red (about 10 min) it's charged. Then uplug it, turn on the copter and fly!
Oct 10, 2010 | Toys
Toys Logo
139 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
