How do I cancel a program once it has started .
    Master:
  • 224 Answers
What is the operating system on your device?
Posted on Apr 26, 2017
Model EWF10843. How do I select diagnostic mode?
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position.
10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00
being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
until the LED's stop flashing
Jun 08, 2015 | Electrolux Washing Machines
Cancel inbox it interfers with my yahoo com
See if you can install it from the program list. Click Start/Programs and see if there is an Inbox Folder. If there is, open it and see if there is an uninstall option.
If not you can click Start/Control Panel and look for Add or Remove Programs. Or it could be Program Features, Uninstall a Program, just depends on your operating system. Open it up and it will show all the programs installed. Highlight Inbox by clicking on it once then select Remove or Uninstall.
May 04, 2012 | Computers & Internet
Cannot find my manual and would like to know how to use the self-cleaning part. I held the button down for "lock", but the door did not lock, and where do I go from there?
Give this a try:
1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds. Momentarily (less than 5 sec.) press CANCEL key again to remove error code display. 2. Program and start the Clean mode. Observe to see if door locks. If it does not, inspect the locking mechanism from the solenoid to the latch pawl and door to find the cause of the problem. If the door is not locking, then 1 minute from the start of the Clean, the F5 E1 code will again be displayed. Press CANCEL key to remove error code display. 3. Once any mechanical problems with the latch mechanism have been corrected, program and start a Clean cycle (after, if necessary, clearing F5 E1 error code) to ensure proper operation of the door lock. Immediately cancel the Clean mode to observe proper operation of door unlock.
If this doesn't help try this link to locate the right model:
http://www.whirlpool.com/catalog/category.jsp?categoryId=76
Feb 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Can you cancel a program once you have pressed start/reset if you have selected the wrong program?
press the stop button until you hear a beep or read out changes, select your new program, then push start
Jan 22, 2011 | Black & Decker B1561 Bread Maker
In the box which tells you what program your on .All that it says is test
Try this.
Press start/cancel button for a minimum of 3 seconds.
Then press start/cancel and on/off button together unti l( Doff) is displayed in the panel
Select new programme, it should now be o/k.
You may have to do this more than once.
Mar 08, 2010 | Hotpoint Washing Machines
How do you cancel a program once it has started? I f I've started a program and change my mind and switch it off it just goes straight back into it where it left off when I switch it back on. It's annoying
Depending on the make of washer which you do not specify, most brands now have a cancel button, you press this to cancel the programme, and reselect the new programme., it may be incorporated in the start button.
I cannot be any more specific, as you have not given the make.
Feb 08, 2010 | Washing Machines
Need a manual for my kenmore elite he3t front load washer
My Kenmore Elite HE3 has been great for many years, and now I have a little problem for the first time.
I can usually press cancel to change the program. This morning, after I selected one program and press cancel, it won't cancel. Lights just blinked. So, I press Start to wash with selected program, but it won't start. It won't start nor cancel no matter what I do.
Should I unplug the unit?
Thank you so much!
Apr 03, 2009 | Kenmore Washing Machines
Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Dec 26, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
