Question about Building Materials
Where can i found a manual for digi door 24 garage opener
geemarie
  • 876 Answers
SOURCE: craftsman garage door opener instruction manual
Have you tried the manufacturers site at either craftsman or sears. You should be able to find it there. You will need your model #.
Posted on Aug 01, 2008
j_del
  • 1586 Answers
SOURCE: PROGRAMMING IN CAR GARAGE DOOR OPENER TO GARAGE DOOR
Usually you just hold down the button in the visor, and while you're holding it down, aim your garage door opener at it and hold that button down so the frequency is grabbed by the built-in opener. That's how it worked in a few other cars that I've seen - try it out and see if it works for yours.
Posted on Sep 10, 2008
  • 548 Answers
SOURCE: garage door opener won't open garage door
did you use the manual release to unlatch the door from the opener? You may have a problem with the door binding and opening it manually will confirm that. You may also have misaligned the sensors at the base of the door so check that too.
Posted on Feb 06, 2009
clyde2j2
  • 137 Answers
SOURCE: Garage door opener
You should have two buttons on the unit in the garage, press the first one and the light should go off, if it's like my Chaimberlain the light signals that the remote is locked out.
Posted on Mar 24, 2009
  • 3197 Answers
SOURCE: Liftmaster pro garage door opener opens randomly
This problem is most commonly caused by a bad wall control or the wiring to it. The staples holding the wires can cut through the insulation and cause intermittent shorting. The wall control goes bad from constant use.
Posted on Sep 11, 2009
Why is it when they get old enough to start needing repairs no one responds anymore? Not just this but everything.
Craftsman (LiftMaster) Garage Door Opener Won't Open or ...
? 9:29
https://www.youtube.com/watch?v=w4bgS9_u2u0
Aug 9, 2011 - Uploaded by Kris Kasprzak
Learn how to replace stripped gears in your Sears Craftsmanautomatic ... This instructions should be good for a Liftmaster,Chamberlain, ...
Manual Disengage for LiftMaster/Sears Garage Door ...
? 1:24
https://www.youtube.com/watch?v=y6q5I_JaEoI
May 21, 2012 - Uploaded by Brandon Bailey
Manual Disengage for LiftMaster/Sears Garage Door Opener ....to Replace the Circuit Board on Chamberlain Liftmaster, Sears, and Craftsman ...
Nov 08, 2015 | Sears Craftsman LiftMaster Chamberlain...
How do I get a free service manual for digidoor 24 garage door opener
Your first problem is you bought a digidoor garage door opener. But check their website, or call the manufacture. You will either be able to download the manual or have to buy a one directly.
Mar 28, 2015 | Building Materials
Program a garage door opener, digi-code?
Is digi-code the brand?
On a liftmaster unit, the instructions are posted on the side of the opener as coding a new opener requires the pushing of a button on the opener.
Dec 04, 2014 | Building Materials
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
My stanley garage door opener motor runs but it won't open or close my door
If the motor runs and the chain does not then you have stripped the gears and will need to replace them. If the motor runs, the chain moves but the door does not move then the trolley is not attached or needs to be replaced. Thanks BB
Jul 27, 2010 | Digi-Code Digi Code 5202 Garage Door...
Building Materials Logo
35 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
