Question about Minolta Office Equipment & Supplies
My printer konika minolta c451 doen't work it show me error code c-3921 what can do to make it work
  • Minolta Master
  • 6,161 Answers
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch. leave sub power switch on
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Posted on May 06, 2017
How to solve error code c-2553
The toner abnormality you have to clean toner hopar and clean senser and again OFF and ON
May 23, 2015 | Konica Minolta C451
I have a C - 3921 trouble code in Konica Minolta c451
Replace the fusing unit. Reset the copier power off the machine, with the utility/counter depressed power on until trouble reset appears, touch it see OK. Power off wait 10 seconds power on. if no code ok, if code re-appears do NOT Reset, machine is telling you it is broke if you reset again it can catch on fire the code you are messing with the is the fuser the hot part, it will ruin a perfectly good day. Get fuser replaced. about 800.00
Feb 27, 2015 | Konica Minolta Bizhub C452 Copier
ERROR CODE 3921 BIZHUB 450
replace the fuser unit.
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Then reset.
use this procedure:
Feb 03, 2014 | Konica Minolta bizhub C450P Laser Printer
Err c-3921 bizhurb c451
One of the sensors on the heat roller of the fuser unit is faulty...replace this sensor or the entire fuser unit and your problem will be solved
Nov 11, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Reset err code c-3921 bizhurb c451
You might Google the printer name and the error code. This is just a shot in the dark, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings. You will loose any settings and any work in progress. Just a guess. If you have an owners manual, I would check there to find how to solve the problem. There is normally a section that defines the error codes and gives solutions. You also might want to enter the "menu" if there is one, and discover whether you can solve the problem there. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section. Good luck.
Minolta bizhub C451 reset fuser code c-3921
Turn off the machine. Ensure the sub power switch (One on side of the control panel is on) Now hold the utility/counter button down and turn on the MAIN POWER switch. HAVE keep the button down when you see TROUBLE RESET on the screen touch it get OK. Power off the machine Wait 10 Seconds before powering ON. If the code comes back do not reset a again because your messing with the FUSER the hot Part which can CATCH ON FIRE and that will ruin a perfectly good DAY! Have a qualified Tech look at it or order a new fusing unit.
Oct 19, 2012 | Minolta Office Equipment & Supplies
Error c3921 konica minolta c451 error c3921 not known what to do
C3921: Fusing sensor wire breaks detection (Center of the heating roller)...
• At the warm-up stage, the heating roller
thermistor/3 voltage does not decrease by
predetermined steps (temperature rise)
within a predetermined time.
Check the fusing unit for correct installation
(whether it is secured in position).
Check the open/close operation of the
upper right door.
Check the fusing unit, IHPU, PRCB and
REDB for proper connection and correct or
change as necessary.
If that check still give you error code 3921
Change fusing unit
Mar 16, 2009 | Konica Minolta bizhub C450P Laser Printer
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
