Question about Kenmore 22942 Top Load Washer
How to bypass a lid switch on a Kenmore 90 series washer?
I have a Kenmore washer 90 series model # 110.26902691 which won't rinse,spin or drain.It will start washing and when it reaches "Rinse" it wont do anything.I tried all the cycles and it does the same thing.When I bring the hose down close to the ground it drains.I am thinking it might be the lid switch since it looked kind of loose and didn't seem to work.I opened the washer and everything else looks ok and clean,the pump looks fine.
My question is how can I bypass the lid switch to be sure thats the problem?
  • citizzen Jul 25, 2009
    The lid switch never clicked so I assumed thats the part that needs to be replaced.Got it for $40 online and once I get it and install it I will find out if thats the problem.I was just trying to find out without buying it to be sure.
  • 36 Answers
Bypassing the switch is done by connecting the two(outer 2)wires.thus closing the switch circut to the timer
Posted on Jul 25, 2009
I took a small screw driver and inserted it into the hole, pushing down gently, further then the little plastic arm on the lid could reach. It continued on with the cycle so I knew that was the problem. I took a plastic sheet rock anchor,(the kind that you drill a small hole in wall then slip it in, and when a screw is inserted it expands behind the sheet rock and will not pull out) and slipped it over the little plastic arm on the lid (it pushed the switch a little further in, which enabled me to use until I could replace. The I went to youtube and they have lots of video's on how to take the cover off and fix.
Posted on Aug 23, 2009
  • 3 Answers
Instructions for opening the cabinet of a Kenmore washer to get to the lid switch can be found at this site:
https://sites.google.com/site/gaborlaug/home/miscellaneous/openakenmorewhirlpoolwasher
Posted on Nov 30, 2013
    New Friend:
    Problem Solver:
  • 4 Answers
Highly inadvisable to bypass any electrical connection and unnecessary because it is the lid switch. In Canada an authorized Kenmore repairman would cost $80 flat rate service call, $15 per each 15 minutes plus $45 part, plus tax. Over $180 for a $350 washer new (maybe) to fix what is just cheap plastic screw thread liners that cracked from lid slamming.
The switch can be removed, repaired with 12h epoxy glue, and reinstalled to good as new. A nickel's worth of epoxy, 12 hour cure wait, 15 minutes to disassemble and 15 minutes to reassemble.
Minimum tools. Video here: http://www.youtube.com/watch?v=MFsvLiuTniU
Posted on Dec 04, 2012
  • jbell810
    jbell810 Dec 04, 2012
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Reach under the inside of the machine and use a moirror if required to find switch it is usualy in a slot off to the right side if there pull down on it and if it clicks it likely works but try the machine on spin cycle if machine starts well you have found the problem bend switch up untill it is in the right position and then toy just save a hand full of cash \
  • jamie Jul 25, 2009
    switch is usualy a simple microswitch can be bought for 2 - 5.00 from local electronics store
    take old 1 out and take the switch to electronisc store replace cheeper and faster
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
My Kenmore washer is not draining or rinsing
Check the lid down safety switch. On the lid there is a small spike that goes through a hole when the lid is down.
Under the hole is a switch that allows the timer to advance and the washer to spin only when the lid is down. Two screws hold the switch in place and the plastic switch will sometimes break and be hanging by the wires.
In other words, it is the timer. That is stopping the advance. You may have to replace the timer.
How to replace the timer in Kenmore top load washer
Aug 27, 2017 | Kenmore Washing Machines
Kenmore 90 Series - Heavy Duty Super Capacity Washer - Washes fine but it's getting stuck at the point when it's supposed to drain & spin before the rinse cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Aug 26, 2010 | Kenmore Washing Machines
Kenmore washer 90 series will go through the cycle, rinse, but will not enter spin cycle, or drain the water from the basin. What could be wrong?
Aug 24, 2010 | Kenmore Washing Machines
I have a Kenmore 90 Series Washing machine that will not spin or
Jun 26, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Washer will wash and drain but not spin
Sounds like the lid switch is not working.It is a safety feature to prevent the washer from spinning if the lid is open.If you look a the lid,you will see a small point that sticks out,The switch is locate under the rim,right where that point would contact with lid closed.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore Washer Model 100, 90 series fills and agitates but
most common solution is to replace the lid switch. (the machine thinks the lid is still open)
Dec 26, 2008 | Kenmore 23822 Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Oct 25, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 22942 Top Load Washer Logo
7,992 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
