Question about Kenmore Sewing Machines
I have a Kenmore 158 331. The only problem I have encountered is after 7 rotations the needle seems to stick. It only happens after 7 rotations. Not sure what the problem is. Please advise. Thank you.
  • Kenmore Master
  • 11,444 Answers
If you haven't had your machine serviced (cleaned & oiled) in quite a while, you may want to do that. Sounds like perhaps your machine is beginning to seize due to old oil drying out.
Posted on Apr 26, 2017
What size needle is used on janome model 672
Janome makes sewing machine needles. However, many machine brands recommend using their own brand needles (ie Singer recommends only their needles and I have encountered issues using Singer needles with non-Singer machines). Sometimes, machine-brand needles are higher priced. More expensive does not guarantee better quality. However, unbelievably inexpensive off-brand needles may not be a good thing.
Janome needles will most likely work fine on your machine, however, most modern sewing machines accept the standard 705/130 needle. Beware, though, that some brands of 705/130 needles have slight variations that may cause problems. If in doubt, consult your Janome dealer or an experienced Janome user. It may come down to experimentation on your own. Don't be surprised that a brand recommended may work better than others. Because a sewist is a staunch advocate of a particular brand, does not mean it will work best for your machine. It's just the nature of the beast because every machine and every needle has slight variations. Purchasing a single package of brand needles and trying them first would be a good idea. If the needle doesn't seem to work, you can try another brand until you find one you like. When experimenting with a different needle, start out sewing slowly (or hand rotating the wheel) in case there is a problem with the needle, you may avoid broken needles.
I've found several brands that work fine on my machines (not Janome machines) and seem to work for most sewists, ie Schmetz, Organ, Klasse, even Kenmore. It's probably best to avoid lesser known brands or bargain bin needles. Fabric stores, like JoAnn's carry Schmetz and if you use coupons, you can frequently buy them at a great price, sometimes 50%.
sewing patternreview com
How to Choose Sewing Needles Looking at Types Sizes Lifespan
Along with choosing the needle for your machine, you need to consider the thread and fabric you will be using. Choosing the correct needle is very important for your sewing success, ie use a ball point needle for knits, a leather needle for heavy fabrics/thread, a sharp/microtex for fine wovens, embroidery for applique & embroidery, top stitch for larger threads & heavier fabric, etc.
All About Needles
And, above all, install a brand new needle frequently, ie whenever beginning a new project. A bent/dull/damaged needle will cause all kinds of frustration, including failing to pick up the bobbin thread, skipped stitches, or even hitting/damaging the presser foot, needle plate, or hook. A flying piece of needle is not a pleasant experience--and dangerous (wear eye protection)!
Jul 22, 2016 | Janome Sewing Machines
Where are the oil ports on an old Kenmore 10 sewing machine #12511..thanks
If your older Kenmore is mechanical (not computerized), it probably can use a bit of oiling beyond what the manual recommends. Older machines frequently were pre-oiled at the factory, however, after many years, the oil tends to dry out and cause the mechanical parts to stick (the reason most older machines are frozen). Perhaps this link will be of help:
It was working now it seems to be frozen the needle part wont move
Feb 10, 2016 | Kenmore Sewing Machines
Have a Kenmore 1357. Was working perfectly until I began sewing satin ruffle onto fleece. Seems to siege. Needle won't even try to go into material. Just goes to top of presser foot and stops.
Is it a mechanical machine (not computerized)? Did you oil the internal metal parts that rub against other metal parts? With an older mechanical machine, frequently the old oil turns to goo and sticks things rather than lubricates. Use only fresh good quality sewing machine oil. Hand rotate the wheel and place 2 drops of oil every place metal rubs metal (including the bobbin area). To help loosen things, direct hot air from a handheld hairdryer into the interior of the machine.
This process was used on an older Kenmore that had totally frozen, but it was working again within 15 minutes.
Dec 11, 2015 | Kenmore Sewing Machines
The needle is getting stuck in the fabric on my Bernina 1008.
Sounds like it needs to be serviced. Needle should NOT be hitting the bobbin case.
Since you don't want to have it serviced, you might check to make sure the bobbin case is inserted correctly and that the bobbin rotates clockwise as you are looking directly at it in the case. Also, is you needle compatible with the fabric?
Jul 29, 2017 | Bernina Sewing Machines
My thread keeps breaking. bobbin thread seems to be alright, have changed thread, needle.
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Dec 16, 2012 | Kenmore 19606 Computerized Sewing Machine
I can thread my machine but when I try and catch the bottom thread (in the bobbin) it wont catch. Im not sure why
Check that the needle is in correctly, flat shank to the back. This is first thing to check as the hook rotates around and catches the thread from the back of the needle as the two come together to form the stitch. So if the needle is in wrong, the scarf at the back (scooped out area) won't be there and no stitch. Make sure needle is inserted fully up into the housing and that it is the correct system needle (most machines use the 130/705H system). Put in a new needle from the pack to make sure.
Is the bobbin in properly, rotating the right direction and under tension. So check needle, check bobbin, rethread everything and try again.
There is good general machine info on which might help you too.
Less likely but it does happen, is the timing could be out, so the needle at the bottom of its movement and the hook swinging around it are out of sync. Timing can be knocked out if there has been a jam up, needle striking the sewing foot or something similar. If you suspect that this is what is going on, then probably time to take machine to a technician who can repair this.
Apr 10, 2011 | Kenmore Sewing Machines
Old kenmore sewing machine model # 1237 ( not found in search) - prob. purch.'d in 198o's
Check the handwheel. If it is pulled out, the clutch is not engaged. Try pushing it in! (It would be really nice if the solution is this easy!)
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Needle is hitting the round , turning case that revolves around the bobbin
It sounds like your timing is off because what you're describing is exactly what happened to me last summer. I took it to a sewing machine repair shop and they repaired the problems, gave it a nice cleaning and it was like new when it came home. But it took two weeks (not a lot of repair shops around here) and that was torture as it's my only machine!!! :)
Aug 17, 2008 | Euro-Pro 9120 Computerized Sewing Machine
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
