To download dstv remote - Televison & Video
How to reset explora remote
To set the remote to mode 3: press and hold both the i and BACK buttons for 3 seconds or until you see the green light blink on 1 and 2 (below the i and BACK buttons). The DStv Explora must be set up to "listen" for the correct mode. You can do this in DStv Central. Press the DStv button
Jun 29, 2017 | Computers & Internet
My dstv remote works well except the pause / fast forward / rewind
It sounds like a contact fault to its buttons inside the remote control. Your remote control need to have cleaned. To clean it, you have to open it and take the printed circuit board inside it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
One among the post by this site have details about how to clean and check a remote control. Surf the site with patience.
Mar 21, 2014 | Televison & Video
I had to buy a new DSTV remote as the one I bought a year ago (Model A3) its Rewind and Fast forward buttons broke. The new DSTV remote, Beyond Platinum Model A4 I can't seem to set it up on my Sinotec...
To select a suitable universal remote control to your device, you should know about the setup codes to your device can respond. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Check these links, and find out, which brand remote control have setup codes to your device, and buy that one according to availability.
Oct 23, 2013 | Televison & Video
1 Answer dstv remote control is not working despite showing a red light whenever i press any button.please help asap!thanx
my dstv remote control function any time it likes.pls what is the solution it is a new machine.Thank you.
Oct 18, 2010 | Televison & Video
Black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
May 28, 2009 | Sony KP-EF61 61" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
