Question about The Health & Beauty
My battery want stay charged i had to by a maintainer charger to hook up to the battery just to stay mobil help please
SOURCE: Works off 110V and battery, but doesn't charge battery, led flickers fast, battery is fine, can charge it with my normal charger
Decase by removing the eight screws on the back. Check the charging fuse isnt blown. You will find it on the underside of the square circuit board that mounts on the back of the charger port.
Posted on May 23, 2008
  • 57 Answers
SOURCE: Camera will not turn on...charged battery but the charge light blinks instead of staying solid
If battries still blinking , chances are that the battries are buggred...try new battries after fully charging...this is cheaper option to try before trying to open the camera..
Posted on May 20, 2009
  • 103 Answers
SOURCE: Batteries won't charge w/ on board charging unit.
Since you have replaced the batteries and the charger there is most likely a problem with the wiring.
Posted on Nov 10, 2009
SOURCE: when my acer aspire 5734z
It is a sign that your battery is failing. Try to remove the battery then put it back. After that, try to check if you still experience the same thing. If so, then you need a new battery replacement.
Batteries usually start to degrade after a year or after 500 charges, whichever comes first.
Posted on Feb 11, 2011
  • 11 Answers
SOURCE: HP window mobile phone Model: -hw6915, Serial No.
Try charging it on the wall plug. Sometimes desktop chargers only charge 60% of the battery, and in the phone appears as 100%.
Posted on Mar 21, 2011
Why does green light on charger stay on?
Most pride chargers show up the green light when batteries r charged...when charging u should have a red power led & an orange led ...hope this helps
Jan 07, 2016 | Pride Mobility Products Go-Go Elite...
Can i over charge my mobility scooter go go pride
Yes you can overcharge a battery, it all depends on the charger your using. Most chargers are single stage chargers. Most scooters come with a single stage charger. My scooter has a built in single stage charger What this type of charger does is output a constant 24v @ 4amps.The problem is batteries amperage requirements decrease as the battery charges. An overcharge will occur when the battery is charged. It requires very little amperage to maintain a charge on a fully charged battery. A single stage charger like mine will output 4amps regardless of the state of charge of the battery. Batteries bring charged with single stage chargers loose their electrolyte. What happens is overcharged batteries break down the electrolyte into oxygen and hydrogen. So overcharging will cause a battery to "boil-out" its electrolyte. Batteries don't work without electrolyte. In the old days there were only single stage chargers. That was the state of the art back then. So to cope with the constant overcharging batteries had refill ports where you could replenish the electrolyte using distilled water.
Scooter batteries are far and away different from the lead acid of the 1970's. Scooter batteries are sealed, they are deep cycle, they use a glass mat soaked in gelled electrolyte. These glass mat batteries optimize the electrolyte used so they can use allot less of it. These newer batteries have a lot more power in a lot smaller package but they have a draw back, they must be charged properly. You can absolutely can not charge these batteries with a single stage charger. Actually you can charge with this device but you will loosed electrolyte each time you charge.
I use a three stage charger 24v @ 5amp. This charger s different from a single stage. Its what they term a "smart charger" it monitors the state of charge of the battery. As the battery charges it turns down the amperage. When the battery is fully charged the amperage is turned low enough were the charge is maintained. The entire charging process is designed to preserve electrolyte. In short this type charger will not overcharge the battery.
Click here to see the charger i currently use.
Jul 30, 2012 | Health & Beauty
Problem with mobility scooter
Take the batteries down to a battery shop and have them load tested. Make absolutely sure they are DEEP CYCLE batteries. My 35a\h batteries put out 480 cranking amps. The battery shop can also test your charger. I have two chargers for my scooter the 4amp charger that came built into the chair, and a really nice three stage 5amp external charger. My scooters batteries have two 50amp quick disconnect connectors. I made up an external harness for the 5amp charger with the same connectors. I can now charge up my batteries out of the scooter. They say my built in charger is a 4amp charger, its slow in comparison to the 5amp charger. Batteries are expensive, regular chargers charge at one rate, full speed and can overcharge a battery. A three stage charger is by far way batter on your batteries. When you start to charge a depleted battery it put out full 5amps but as the battery nears being charged the charger backs off the amperage. When the battery is fully charged the charger goes into float mode and put out just enough amperage to maintain the charge. When i'm not using my scooter i keep the batteries connected to this charger. Deep cycle glass mat batteries don't stay charged very long when just sitting around. In about six months a dead battery will sulfate to the point where it will no longer take a charge. That happened to me once and cost me $200, never again will this happen to me. Battery shops are great places they have the instruments to tell you everything you need to know about the batteries. The batteries are the heart of your scooter unless you know there condition all kinds of strange things can happen. To make sure my batteries were good i have them checked against a known good set of batteries. BTW- Cranking amp is measured by putting a load on battery and increasing that load until the voltage falls off. At the point just before that voltage drop they measure the amperage output, that is you're cranking amps
Jun 22, 2012 | Electric Mobility Health & Beauty
I have new batteries and charger but batteries will not charge
If your battery is totally flat some chargers see this as connecting to a short and will not charge. If the battery has a charge run it down some, my batteries often don't take much of a charge if any. Does the charger light up.Does the charger have any fuses on its out put wiring. Open the charger up, do you see fuses. When the charger is on do you see any blinking lights. If you get a blinking yellow light when hooked to a battery there is something wrong with the battery. Hope this helps
May 26, 2012 | Pride Mobility Products Health & Beauty
When i open internet with the help of my mobile phone then after sometime my mobile automatically switch off
Make sure your battery stays charged.Hook it to the charger.If that is not the problem,try to format the phone/do a software update
Aug 04, 2010 | LG Cell Phones
The battery charger in the trasfer case is not charging the battery
have you tested the battery to see if its a good one? if its a dud it wont charge up, and whet tests have you done to see if it realy is not charging the battery, the times iv had this,,, its not charging,,, when it was, but the battery was a dud,
however check all the fuses and trips and put an avo meeter set to amps x10 in line with the battery after you have started the charget to see if it realy is not charging up,,, if its not look at the rectifier,,it may have a blown diodes in it
Nov 05, 2009 | Watts Onan Portable Generator - 5000 ,...
I need to know what battery in float mode means on my battery charger. It doesnt say and its a smart charger 2amp 6amp and 12amp charger.
Float mode on a battery charger generally means that battery has been fully charged at a faster rate, and the charger is now maintaining the full charge, without overcharging the battery. You can usually leave the battery connected to the charger indefinitely - float mode will ensure it is always at it's peak charge.
Please rate if this helps :)
Mar 05, 2009 | 2003 Ford F150 Regular Cab
Batteries are charged, scooter won't move, no power to display
It is impossible to overcharge with the Pride charger. When the battery is full, it will stop charging and check about oncew a miute to maintain the charge.
Now, when you plug in the key (looks like an audio headset jack) does the battery meter indicate a full charge? Also, the scooter will not move if its in free wheel mode, and it will not move if the charger is plugged in. Beyond these first steps, you will need a voltage meter to troubleshoot.
Jan 18, 2009 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
22 people viewed this question
Top The Health & Beauty Experts
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
