How many Pcs can be connected to an sps? - Computers & Internet
Service Air Bag light on
DTC B0058 Right Front/Passenger Pretensioner Deployment Loop Open.
The passenger seat belt pretensioner deployment loop consists of a seat belt pretensioner-RF and the seat belt pretensioner-RF high and low circuits. A shorting bar used within the seat belt pretensioner connector shorts together both the seat belt pretensioner high and low circuits when the connector is disconnected. This will help to prevent unwanted deployment of the pretensioner during servicing. During a frontal crash of sufficient force the inflatable restraint sensing and diagnostic module (SDM) will allow current to flow through the deployment loop in order to deploy the seat belt pretensioner. The SDM performs continuous diagnostic tests on the deployment loops to check for proper circuit continuity and for shorts to ground or voltage. If a malfunction is detected, a diagnostic trouble code (DTC) will be stored in memory.
DTC B0084 Left Front/Driver Seat Position Sensor Circuit
The inflatable restraint seat position sensor (SPS) is used to determine the proximity of a front driver or passenger seat position with respect to the frontal air bag. The SPS interfaces with the sensing and diagnostic module (SDM). The state of the SPS allows the SDM to disable stage 2 of the frontal air bag for a front seat that is forward of a forward/rearward point in seat track travel. The SPS is a hall effect sensor that is mounted on the inside seat track of both the driver and passenger seats. The seat track includes a metal bracket that shunts the SPS magnetic circuit creating 2 states of seat position. The shunted state represents a rearward seat position. The non-shunted state represents a forward position. The SPS provides 2 current ranges, one range for the shunted state and a second range for a non-shunted state. These 2 states are inputs to the SDM. State 1 (shunted) being the rearward threshold and state 2 (non-shunted) being the forward threshold. When the SDM receives input from a SPS that state 1 threshold is reached (seat is rearward) the SDM will not disable stage 2 deployment, if required by the deployment sensors. When state 2 threshold is reached (seat is forward) the SDM will disable stage 2 deployment on the side the seat is forward. The SDM monitors the SPS circuit and if a fault is detected the SDM will set codes B0083 or B0084 and defaults to disabling stage 2 frontal deployment. This will only default on the side of the vehicle the sensor has a fault. Its important to understand that the SPS is secondary to the passenger presence system (PPS) and the manual instrument panel (I/P) module disable switch. If either one of these devices are in the disable mode the passenger air bag will not deploy regardless of the SPS status.
You should take this to a qualified repair Shop ! Takes special tools to test .
Feb 26, 2016 | 2006 GMC Envoy
How should I wire a 4 channel amp for alpine sps 600, 609
they are only 4 ohm speakers so just put the front speakers on channels 1&2 or a&b and the rear on 3&4 or c&d since you are using a 4 channel amp thats what they are designed for
Jul 09, 2010 | Alpine SPS-600C Car Component System
Sps 1000 - pc connection
The usb port isn't in your cash register. Your cash register has a serial port that should look like this: 70b547a.jpg
You should have a cable that has a USB connector at one end and a port that will accomodate a cable like pictured above.
Apr 16, 2009 | Microsoft CompuRegister POS-1000 POS...
Im having trouble installing the sps-600c alpine speaker system. i need a wiring diagram or somthing as im un farmiliar with split speakers that dont have a cross over.
Hello lucal_s2000,
Well, actually those 600c's do have a crossover. It's encapsulated in the wiring you got with the components. Your head unit or amp speaker outputs connect directly to the woofers. The inline crossovers have a 12" wire on one end and a 22" wire on the other end. Connect the 22" side to the 2nd set of terminals on the woofers, and the 12" side to your tweeters, keeping all of the positives and negatives straight.
Here's an image of the connections.
5eca958.jpg Hope this helps.
Apr 12, 2009 | Alpine SPS-600C Car Component System
How to run a pirated dvds in sps 2 slim
you only need a modchip to play pirated PS2 and PS1 games.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
