Question about JVC Audio Players & Recorders
When i want to play music in jvc MX-D302T from a mobile phone using aux cables it is not working .what should i do
5 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I purchased a used JVC
Look on eBay. I see two. Simple web searches find answers, too.
Posted on Aug 26, 2011
  • 43 Answers
SOURCE: Hi i have a jwin jx cd6700 system and im trying to
not possible. unless you connect through head phone. it takes two kinds of different cables. better to download of internet music to cd
Posted on May 07, 2012
  • 5418 Answers
SOURCE: Need a maual for JVC MX-D302T
JVC has the manual available for the MX-D302T here: http://www.jvc.co.uk/files/instruction_manual/ib_mxd302.pdf . This is a PDF so you will need Adobe Reader or a similar program to read/print the file. You can special order a print copy of the manual and the remote from http://www.partstore.com/Model/Matsushita/JVC/MXD302T.aspx . Scroll down to find them in the parts list.
If you want to order the remote separately, remotes.com has a substitute remote from JVC for sale: http://remotes.com/store/jvc/mxd302t.html . Amazon also has a replacement remote available: http://www.amazon.co.uk/Remote-Control-Replacement-JVC-MXD302T/dp/B005LQA4JK .
I hope this helps.
Posted on Nov 19, 2012
  • 2896 Answers
SOURCE: Is my iPhone 5s not compatible with the AUX feature? Using a working audio cable, but not playing music.
Does your phone work with ear buds? If so, it's not the phone. Test the AUX with another source...
Posted on Jun 11, 2015
Can I use an 3.5 mm aux cable to play music from my phone thru jvc home theatre system th-60?
Yes you can. You will need a cable with two phono plugs on them. If it has a front mounted socket use that. Set the phone volume to no more than half and use the JVC volume to control it.
May 09, 2018 | JVC Audio Players & Recorders
My jvc mx-kc58 compact shelf stereo the aux in mode sounds far away an i can barely hear the words in aux mode only cd player sounds normal
It sounds like whatever is connected to the aux socket has a bad earth connection check and replace the cables to it.
Dec 23, 2016 | JVC MX-KC58 Shelf System
How do I get my iPhone 4S to play music from my itube app on the jvc kd-s37
It looks like the JVC will control the iPhone as a music player through the USB. However, unless the YouTube app or another app can give you that same control, the simple answer is to use an aux cable (3.5mm stereo/headphone jack on both ends). The problem with this solution is you will have to select your videos and/or music through the phone. Unless you have a YouTube playlist set up, I would not recommend you do this while driving.
Dec 29, 2013 | Cell Phones
I hope this helps.
Nov 18, 2012 | JVC MX-D302T Shelf System
Unable to play music files from mobile, saying no audio device connected, whereas i can receive the call from the system. Thanks, ..Amit
Your stereo have the bluetooth connection to be used only for the headset profile (IE to making and receiving calls). To read the music from the phone you need to connect it using a USB cable and put the phone on "Memory card" or "Mass storage" USB mode.
If that doesn't work is because some phones simply can't be read with devices other than computers because they use windows drivers to enable the data access.
Oct 28, 2009 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
Power cuts off
This is not a fuse problem. I would suspect that the output amplifier section is getting too hot and shutting down. Check you speaker cables and make sure that they are not shorting out at all. If they are OK, then there is a problem with the amp itself that will require bench time to resolve.
Keep us posted.
Dan
May 28, 2008 | JVC MX-D302T Shelf System
Stereo component
It has a driving motor belts problem so send it to service provider.
Feb 26, 2007 | JVC MX-D302T Shelf System
Cassette player on mx-d302t
Hi As you know cassette decks have been around along time, and as such they are fairly robust. The vast majority of the time, problems like you are describing are the result of a broken drive belt, or bad capstan motor. This is not true for all, but if you have favorite tapes you wish to play, you need the deck fixed, and if the problem is drive belt or motor, the repair normally should not be hugely expensive. Hope this helps, good luck!
Feb 23, 2007 | JVC TD-W118 Single Cassette Deck
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
