Computers & Internet Logo
Sandra Suter Posted on Apr 26, 2017
How do I get steps on vivofix 3 face? - Computers & Internet
2answers
Forgotten password for Hotmail account. How do I recover
In case you lost your Hotmail account password and you face issues while you want to recover your lost password then follow these given steps and fix your issues instantly.
Steps to recover Hotmail account Password
Step 1: Go to the Reset your password page
Step 2: Choose the reason you need your password reset
Step 3: Then click Next
Step 4: Enter the email address
Step 5: Phone number
Step 6: Enter recovery code
Step 7: Enter new password
Step 8: Follow on-screen instruction
After following these steps I am sure you will recover your Hotmail account password. But, if still, you face issues then visit Reset Hotmail account password service and fix your issues instantly.
To download whatsapp for my pc
web version of the Whatsapp called web.whatsapp can be installed on pc. You can chat using the pc instead of the phone.
step 1. go to https://web.whatsapp.com/ on your PC.
step 2. launch whatsapp on your phone.
step 3. touch the top right icon of 3 dots and then on whatsApp Web
step 4. place your phone in front of the large QR code with its rear camera facing the pc screen.
step 5. Press scan on phone.
step 6. you may have to move your phone little forward or backward to see entire code
Remember the web.whatsapp will work only as long as both the phone and pc are on internet.
How to replace break light switch on 98 maxima
its just a little switch that bolts on to the petal i think its a 12mm or 10 mm nut.
step 1) unhook the battery.
step 2) locate switch to do so just lay on back with head under dash and follow the break petal up it will be the one facing the front of the car toward the engine with the pug in part facing toward the front seat.
3.) remove the wire connection then the bolt holding it on and their you go.
How to hook up a precision vtec controller
Step 1. Kick yourself really hard .
Step 2 grab all the wires in the back of unit.
Step 3 cut as close as you can to unit removing wires
Step 4 recycle wire in the attempt to recoupe some of your wasted money.
Step 5 firmly grasp 32oz ball pean hammer
Step 6 place unit on the ground
Step 7 aim hammer for center of unit
Step 8 swing from texas ensuring contact with hammer face is close to center, repeat if necessary
Step 9 clean up your mess
Step 10 put all tools away for this project
3answers
I can not log in to yahoo messenger
Hello, are you using a proxy? Anyway, try this..
STEP1
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, UNCHECK it.
5. Click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account now.
STEP2
There are 3 step to repair yahoo messenger error
If you got yahoo messenger error then there is a 94% chance that your computer has registry problems. To repair yahoo messenger error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair yahoo messenger error.
Hope that helps!
GOOD LUCK!!!!!!!!!!!!
2answers
Hw to open the battery cover?
I have one of these (a real work horse) -- from your picture the phone is facing upwards.
Turn the phone face downwards - at the bottom end of the phone (connector end) there is a depressed plastic tab - that has to be pressed inwards and and the cases just slides OFF.
I did find that it isn't as easy as the lady in the shop found it - she just pressed her nail into the plastic tab and presto the case slid off.
I had to stick a paper clip into mine - but it does come off that way -- good luck -- Ray
My email id n password is correct den though my email account is not opening..... "incorrect password and email id" is d error shown..
Please follow the below step for your problem
step 1: Open http://edit.yahoo.com/forgot?login
step 2: Click on i forgot my password or whatever you face problem
step 3: click on next
step 4: do as per instruction.
thanking you
davevipul197
Jan 04, 2011 • Yahoo Mail
1helpful
2answers
Install wheel bearings for 1998 dodge ram 1500
you cant just change the bearings they are sold as one unit spindel and all about $300 bucks for the part.
Lawnmower lbade assembly sequence
1. install round washer first flat side facing you.
2. round plastic washer next flat side facing the washer.
3. next step blade.
4. next step square plastic washer label facing you.
5. then the square metal washer, make it flash with the shaft flat side.
6. tighten nut by hand at first then use impact tool if you have.
Grand Canyon Tech
Grand Canyon Tech
