Question about Lands Phones
Konica Minolta DI 5510 code solution please. machine gives when the planes take off. cant solve it, too much confused wid this condition
Need answer.
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
SOURCE: error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Posted on Sep 22, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
SOURCE: Minolta Fax 3900 problem at work
I have a Minolta Fax 3900 and it at times while trying to send a fax will say *tx cancel* and only send 2 pages of a fax. It appears like it does send the fax but it might not be the complete fax. I can't cancel the fax or stop it either. Does anyone know how to fix this problem.
Posted on Apr 30, 2010
WHEN TRYING TO CLEAR A PAPER JAM, I PRESSED DOWN LEVER A; BUT WHEN i TRIED TO PULL OUT THE UNIT, IT SEEMS LOCKED AND WILL NOT COME OUT?
Check the actuator if deform or sometimes a small torn off paper remains on it. Position the leve A down steady before pull.
Dec 02, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Why is amy copier throwing a sc 49-1 code?
What do you mean yo cleaned the control board?? Did you remove it????? IF you did major problem a Will have to go back and remove each connector looking for a bend pin and ensuring each connector is properly seated. Never remove board unless required. As for the code: please check code could not find in the service manual
May 22, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Error code 42-2
Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 19, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Di650 error code 42-2
FM-2 Fan code, Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site
No work machine code sc23-03
clean and inspect the drum cartridge replace the drum and the cleaning blade when was last time pm was done do be done ever 250,000 copies do one.
Mar 14, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
I have 650di minolta machine. now it the start code No sc36-02 emerged. please tell me the soloution
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem with the fuser (The Hot Part) the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Feb 14, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Error code sc23.03
Minolta Di 750 error code SC-23-01 i want solutions this code.
Sep 17, 2013 | Konica Minolta Minolta Di 650 Di 551 Di...
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
My konica monilta di 450 is giving error code c-13fa please help and give me its solvation?
PRINT HEAD failure that is the unit the LASER is in. try open close front door, check connection between print head and image control board if not need a new print head.
Dec 28, 2011 | Minolta DI-2010F Copier
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
