No matter which tv channel I set my TVs to with my remote,the TVs still goes on to channel 1
jomaru
  • 337 Answers
SOURCE: Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Posted on Sep 13, 2006
  • 1153 Answers
SOURCE: AIWA VX-T1420 Setting Channels
No it should not light up. If you can not go into menu and add channels manually or auto program. Then you will have to get a remote to work. You could order original remotecontrols.com.
Posted on Sep 23, 2007
  • 52 Answers
SOURCE: won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Posted on Mar 07, 2008
  • 285 Answers
SOURCE: I can't change the channels on the tv with remote or on tv contro
You will need to rescan for channals, or manually enter the number. Make sure your sat. box is on when you do this. Rescan can be found in your tv.s menu.
Posted on Jul 03, 2009
  • 374 Answers
SOURCE: The two TV are synced. Do I unconnect them?
If you have a dual tuner it is in sigle mode. Go to the front panel on the receiver and press the mode button. This may be behind a push open door based on the receiver you have. If this does not work let me know. Thanks for using Fix Ya.
Posted on Aug 16, 2009
How do I enlarge the picture on ther screen using the remote
sadly with no make listed , it might be that your set does not have that feature .
May 14, 2016 | Televison & Video
Orion TV 1933 stuck on AUX
I assume that pushing the channel up and channel down buttons does nothing. You could try unplugging it overnight and see if it's forgotten its settings come morning. But if that doesn't work, you're probably going to have to get a universal remote and program it to your TV. Quite a number of TVs (and DVD players and VCRs for that matter) no longer have a full set of controls on the TV. Some things just can't be done without the remote (a fact that really irritates me). -Dyllan
Sep 22, 2007 | Televison & Video
How do i change channels with the bush urc 3541 remote on a phillips tv
Check it by set it up with an other code said to your TV brand. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 16, 2015 | Televison & Video
HOW DO I GET GIG1 OF MY JVC TV SCREEN
Is it a 4k set? If so, that is gig #1 input and you must use the remote to switch around the inputs to the one you have connected.
Feb 11, 2015 | JVC Televison & Video
Apex tv locked
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Mar 13, 2013 | Televison & Video
Red key on screen wont show or change channel
Jul 14, 2012 | Apex Digital AT2702 27" TV
My tv is locked i cant push anything to cut it on it is on but there is a key on the screen and i do not have the remote control what do i do.
hi,
To unlock your TV you must need the original remote of it. If you don't have then you have to purchase it. After the do the following for unlock you TV
Apex TVs have parental locks that allow you to block certain programs based on their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
1. Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
2. Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
3. Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels
ok
May 22, 2011 | Apex Digital AT2402 24" TV
Settting tv to a higher channel for cable`
Most TVs have a choice of air or cable in the menu portion of the tv. press menu go to setup and from there you should see an option that says air/antenna or cable. You will have to either toggle to get the air selection or highlight it. Then you should be able to get to channels you need.
An easier solution may be to go to the Dish receiver that controls the image on the tv you can't get to 73. With tv and satellite on (make sure both green and blue lights are on) press on your Dish remote #1 with the green tab on the bottom the following sequence: MENU - 6-1-5. tHIS WILL TAKE YOU TO THE MODULATOR SET UP PAGE. Move the highlight from cancel to the mode section an highlight AIR and press select. Then move the highlight back to the right to DONE and press select. Press cancel three times or view live tv. then go to the other tv and put it on ch 60.
Hope this assists you.
Sep 09, 2008 | Symphonic ST420FF 20" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Jan 05, 2008 | Sanyo DS24205 24" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
