Question about Saws
How do you get the creases out of the mat you put a jig saw puzzle on. The puzzle pieces will not stay in place and it won't roll up.
  • 242 Answers
SOURCE: jig saw
On the spring loaded one a metal pin will fit through a hole in the black to keep it in place. Ensure your blade is not broken and has a hole for the pin to go through.
Posted on Oct 24, 2008
  • 33 Answers
SOURCE: shower cable wire
Posted on Oct 31, 2008
  • 257 Answers
SOURCE: Problems with Bosch T101BR 4 Inch 10 Tooth Jig Saw Blades
Hi, The reason for a down cutting blade is to see your cut on the finished side of laminates ( which include veneers, plywoods, plastics, formica . When using an upcutting blade on laminates the smooth cut is on the bottom, which you can not see till you are done and turn the work over. Reversing the teeth allows that smooth cut to be on the top. This is usually done on smooth flat surfaces as you have found out and does not work with orbital or tight scrolls. As far as the pushing or pulling, smooth cuts in laminates require the saw doing the work at a speed that allows the teeth to cut and remove material with biting. So if you are biting, (This is a much slower process than pushing your jigsaw through regular wood) check that you are not pushing too hard and that your blade is still sharp. Good Luck to you, this should Fixya!
Posted on Mar 08, 2009
SOURCE: Instruction manual for Bosch Jig Saw 1587AVS[US]/t10/0000000/r00061v-1.pdf
This is the Owner's Manual for the Bosch 1587AVS Jigsaw.
Posted on Jun 24, 2009
SOURCE: task-force-4-amp-jig-saw
how do i change blade on task force jig saw. i am un able to pull it out after pressing button for it
Posted on Jul 01, 2010
How to complete engine replacement on a Dixon are mower, model number DM 3068671 13 up
Hi Denny:
Seriously, this can be a fun project if you have patience, time, a camera, and a secure place to work.
It will be a learning process.
1) Remove battery
2) Methodically dismantle... stay organized.... take pictures.
3) Reverse process with new motor.
4) Install battery.
5) Test run.
6) Have a beer.
I'm really not kidding. Trying to do a step by step, bolt by bolt procedure would not be relevant.
Like a kid with a wind up alarm clock, you take it apart, and put it back together.
Enlisting the aid of an experienced mechanic friend never hurts.
It's really just a sort of jig-saw puzzle that you have to take apart and then put back together.
Have fun.
Jul 09, 2016 | Garden
Jig saw blades wont stay in.
loosen it more before you put the blade in.
Mar 16, 2014 | Skil Saws
What do you call the piece of plastic that you put under a rolling office chair?
The piece of plastic or any other material used to put arolling office chair on top is generally called a surface mat.
May 29, 2012 | Furniture
Need to know how to put blade in
Just pull up on that rectangle shaped black piece on the top of the blade. Then pull the blade out. You can use both type blades in this model. take care and good luck.
Mar 08, 2011 | Skil 468004 5 Amp Jig Saw Kit with Laser
I have a Ravensburger Puzzle Ball Globe 540 Pces and will like to know how to put the last 5 pieces on
To complete puzzleball, assemble the last 5 pieces together before putting them into the ball itself, and then add them to the rest of the puzzleball. You may find it easier to roll the ball along a flat surface, to help ease the pieces into place.
For more information you can go to and they give you a step by step guide on how to complete it
Hope this helps
Mar 02, 2011 | Ravensburger Puzzle Ball Globe 540 Pces
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
How to cut a 45 degree angle on wood using a jig saw
use a combination sliding square to mark ecxactly where you want to cut. Measure the distance from the jig-saw blade to the edge of the jig-saw bottom plate. Use this distance to mark another line parralel to the first line. Nail or screew a straight piece of wood on the second line. Put the jig-saw plate against the wood fence and cut your perfect line.
Mar 17, 2010 | Franke EuroPro Series GN1845SP Solid Wood...
I need a diagram of a Craftsman Radial Arm Saw base
I persevered and finally solved the jig saw puzzle of pieces. The base is now assembled and just waiting for the saw body to be remounted. Thanks everyone for looking at this post.
Sep 05, 2009 | Craftsman Saws
Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Feb 22, 2009 | Bosch Saws
Saws Logo
51 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
