Question about Vulcan Heating & Cooling
Vulcan gas wall furnace will not ignite. Gas on power on Heater approx. 15 years old
  • 15 Answers
SOURCE: Venting a Dayton 4E454 24,000 BTU gas furnace
If you intend to use this in a residential garage, you will have to use standard galvanized round pipe coming off the unit, 24 gauge will suffice, use a minimum of 6”-8” from the unit. From there you will have to make the transition to the B-Vent. Always double check with you local codes in your area.
Hope this helps.
Posted on Dec 02, 2008
  • 8619 Answers
SOURCE: Hi there, I have a Vulcan Gas Wall Furnace Heater
Please see this link to view/download the manual fro your heater---
Vulcan Gas Wall Furnance Heater
Please accept this solution and ask for any assistance.
Posted on Mar 29, 2009
SOURCE: need fan for vulcan gas wall heater serial no. 1003129019
found a supplier using the Google search engine. Thanks any way.
Posted on May 15, 2009
  • 2976 Answers
SOURCE: The pilot light has gone out on an old Vulcan gas
You probably need to replace the thermocouple before you will be able to get it lit.
Posted on Oct 14, 2009
  • 1420 Answers
SOURCE: I have a trouble code 11 on my Rinnai model 2532
11 is a ignition failure code. Could be alot of things, I suggest calling a tech who has repaired these before. Pull the front cover off and have a helper turn on a hot water faucet. Look thru the viewing window to see if the unit is firing then going out. If not, clean out the water filter on the inlet side of the plumbing. You will need to turn off the water supply prior to cleaning it. If the unit fires but shuts off seconds after ignition, you may have a dirty or bad sensor. Call a proffessional at this point. Sorry
Posted on Oct 18, 2009
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download. > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Does Vulcan Pyrox gas wall furnace have a filter? It seems to cycle on and off too often and the gas seems too high. Also it makes a bang when reigniting. How can I turn the gas down inside it?
get it serviced by a licenced gas fitter / plumber. Should be serviced every two years. Don't risk your life via carbon Monoxide poisoning get a licenced gas fitter /plumber to assess the unit.
Jul 12, 2015 | Vulcan Heating & Cooling
Trying to locate replacement parts for my gas wall heater
Bonaire pyrox is the old Vulcan company
Standard Appliance Parts Sacramento California can get you anything you need as well.
Apr 05, 2015 | Vulcan Heating & Cooling
Vulcan wall heater gas issues...
The igniter may be bad and needs replacing.
Jul 01, 2017 | Vulcan Heating & Cooling
My father has to replaxce an 11 year old Vulcan Wall Furnace. He wants a Braemar Wall Furnace. He must tell Braemar what model his Vulcan is - there aren't any model badges. Can he determine if his...
Usually these numbers on most other untits are stamped on a metal plate which is located
or attached to the gas valve, which would also give the BTU Input/Output. Probably the
Model Number as well
Sep 01, 2011 | Heating & Cooling
My vulcan ducted heating unit blows cold air for approx 1 minute when turned on then stops and try's again after approx 1 minute,it does this several times until ignited.It is obviously an ignition...
Two things have to occur here:
1) The ignitor has to light off the gas. A bad ignitor, or dusty burners can prevent ignition.
2) The thermocouple has to be in the flow of burning gas to prevent a safety shut-down, and has to be working.
And the obvious: you need pressure in the gas line, and the gas valve needs to be open.
Hope this helps you locate the problem!
Aug 14, 2010 | Vulcan AUW230A Heater
Hi there, I have a Vulcan Gas Wall Furnace Heater 26.4. Would you please tell me where I can get manual book or how to use it. Thanks! Paul
Mar 29, 2009 | Vulcan Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
