Question about Whirlpool DU960PW Dishwasher
Whirlpool DU960PWKQ1 Dishwasher will not drain completely
Same dishwasher..... will not drain all the way out. Any suggestions?
  • 6,784 Answers
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jul 25, 2009
Dishwasher du930pwpq2 draining but don't start after
It sounds as if the drain cycle isn't completing. I don't know if the drain and pipes are having trouble or if the dishwasher itself needs to be re-calibrated. I would suggest having a mechanic or plumber come in and check it out. Try all the different cycles so you can narrow down what is wrong.
Elisa Jed ' http://aceplumbing.com/drains-and-sewers
Mar 07, 2014 | Whirlpool 24 in. ADP6940 Dishwasher
Whirlpool GU2275X Dishwasher
Does this drain have a vent.add a quick vent to the drain line under sink:
http://waterheatertimer.org/Plumbing-Vents.html
Gene
h
Jul 01, 2013 | Whirlpool GU2275XTVB Built In Dishwasher
I HAVE A WHIRLPOOL DISHWASHER MODEL DU890SWKU0, MY QUESTION IS: EVERYTHING WORKS BUT THE WATER DOESNT GET FULLY DRAINED WHEN CYCLE IS COMPLETE. WHAT CAUSES THIS? THANK YOU
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Whirlpool Dishwashers
Water did not completely drain from dishwasher
check your air gap in the sink. see if there is a clog. check this and let me know
Jun 21, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Standing water in my kenmore dishwasher after complete cycle
heatman101
z
Jan 04, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool model shf 5800 will not drain completely
Did you remove the knock-out in the disposer...if not that's why you are not draining.
Jun 02, 2008 | GE Dishwashers
Did not drain after wash
My Whirlpool dishwasher model no. DU960PWKQ1 will not drain after wash. Dismantled impeller/strainer and there were no clogs.Drainline is clear.
I think motor is reversible, so there is no drain valve? HELP ME PLEASE.
Jan 13, 2008 | Whirlpool DU960PW Dishwasher
Whirlpool DU960PW Dishwasher Logo
1,301 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
