580 supper k will not drive - Computers & Internet
Proform xp 580 - Does anyone know how to remove the control panel cover? Is there a diagram somewhere of all screws?
Look up your model on, they have the user manual, and also the schematics that I use as a Tech. Note that even as a repair tech, I rarely ever get into the console.
Technical note - on treadmills, the top electronic board is actually called a "console". The "controller" is the circuit board that sits next to the drive motor in the bottom housing in front of the drive roller.
Jan 05, 2013 | Proform XP 580 Trainer Treadmill
Loud clunking noise in rear roller of proform 580 treadmill
You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
God bless you
Nov 29, 2012 | Proform XP 580 Trainer Treadmill
How to remove dvd drive
Search HP Pavilion dv6000z Besides a simple search HP offers supper easy removal on some models, including this one.
There is a video.
Nov 24, 2012 | HP Pavilion dv6000z Notebook
Lg portable supper mutli drive failed
Make sure all of your OS updates are installed, try re-booting the computer in safe mode and install drivers in safe mode.
Mar 07, 2012 | LG Computers & Internet
I see no evidence of a place in which to insert a cd to copy/burn in my new inspiron 580
According to dells, admittedly unhelpful store. The optical drive is an optional extra... Unfortunately this isn't of much use to you, if there's really no drive in the machine you'll ahve to either try and return it, or purchase one.
If you decided to purchase one you could go for an internal or external drive. An internal one would be slightly cheaper, however you'd have to install it yourself.
There are some pretty cheap options on ebuyer.
Best of Luck
Jun 11, 2011 | Dell Inspiron 580 PC Desktop
On my Dell Inspiron 580 it will no longer burn CD-R discs.
If it burns other discs just fine and not CD-R discs, I would suggest you try a few diferent brands of discs. That should alleviate your issue. If it doesn't, its probably a good idea if you just replace the drive completely. You have purchase one from a local electronics retailed for around $30.
Mar 14, 2011 | Dell Inspiron 580 Desktop Computer
Case 580 super l stops as i drive it forward
What is the last thing that happened before you noticed there was a problem?
Jan 13, 2011 | Ertl 580 Super M Series II Tractor
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
