Question about Fisher Refrigerators
Fisher paykel French door fridge shows r20 error and beeps as soon as you open any of the doors. After about a minute it stops and starts working as it should.
SOURCE: Fisher Paykel Dishwasher Door Open error code
If it is a dish drawer type there is a clip at the rear of the drawer that holds the drawer closed. you will need to withdraw the drawer partially to look in. with the drawer open the fingers should be facing towards you. If not you will need to reach in and pull the top of the fingers towards the front. there is a replacement arm that holds the pipes and cables away from this part.
Posted on Nov 24, 2007
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker.  Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Posted on Mar 24, 2009
SOURCE: E249T Fisher and Paykel Beeps when door opened
Disconnect the Fridge for 5 mins. After that, should be ok.
Posted on Apr 12, 2009
  • 3 Answers
SOURCE: Fisher & Paykel active smart fridge keeps
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Posted on Nov 07, 2009
SOURCE: Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Posted on Nov 08, 2009
My fisher paykel model number# rf170adx4, serial # rhg755331 fridge beeps every time we open the door (not leaving it open)! It's a brand new fridge.
It is probably just a warning beep to let you know the door is open. It should stop when the door is closed. There may be an override setting to cancel this. Have a look in the Owners book to see if you can reset this or check with your F and P Customer service centre and ask.
Nov 19, 2016 | Fisher Refrigerators
Opening fridge door and it beeps
perhaps the reed switch (the magnetic switch to tell the PCB the door is open/closed).
With F&P fridges, the amount of beeps will indicate the error code which relates to which component is faulty.
Sep 14, 2016 | Fisher and Paykel Active Smart E522B...
I have a fisher and paykel fridge freezer - the problem being once fridge is opened it keeps beeping and on the front panel it shows a spanner flashing
sounds like the door opening switch must stick. find the switch, should be visible near the hinge area of the fridge and spray some wd-40 into the housing. that might work!
Jul 03, 2016 | Fisher and Paykel Refrigerators
The door alarm of my fisher and Paykel E372B fridge goes off when the door hasnt been opened for a number of hours. How can I stop this.
You would notice that when it beeps, there are a series of beeps, which relate to an error code - also, the temperature panel would be most likely flashing the same amount of times the beeping occurs. The code relates to a component failure that the active smart system is having problems with.
For example, 17 beeps would be error code 17 - which relates to the freezer fan is drawing less current than is expected. Either the wiring is open circuit or the fan is faulty.
Feb 18, 2015 | Fisher and Paykel Refrigerators
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Fisher paykel e381t
It is probably no more expensive than a CONTROL BOARD...
POSSIBLY as cheap as a door switch...
It is sensing a DOOR ALARM... and quite reasonably
stopping ... and alarming.
You need to find the PIZZA box, poor door alignment
or FAULTY circuitry that is causing the ALARM.
Contact the maker for support
(on your back panel... or by reading your Owners Manual).
Like (example)...
Fisher Paykel E331T Installation Instructions And User Manual Page 44
Hope this helps
Carnac the Magnificent
Jul 28, 2017 | Fisher Refrigerators
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 | Dryers
Fisher paykel French door fridge shows F20 error everylme the door is opened - it beeps
F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires together with a auto12v type connecter or solder it and use shrink tube. Switch the fridge back on and hay presto, you can fill your fridge to the max 3 times over with the money you just saved. It will happen again as the wiring loom they fit is well and not flexible. Use silicone insulated wire from J-car or similar and replace from the plug and reconnect inside the door where the wires don\'t bend. Hope this helps you.
Feb 15, 2013 | Refrigerators
Refridgerator E249T the beeping alarm wont stop. The door appears okay. How can I disconnect the alarm, please? Thanks Brian
I have the same fridge. It was driving me crazy. I emptied it. Cleaned it. Defrosted it. And was ready to dump it. Then worked it out. As it beeps when the door is open. How does it know. Because when the door is open the light is on. I taped up the light nob with masking tape, on top left of fridge. No light now
But no beep Yay!!!!
Jun 14, 2010 | Fisher and Paykel Fisher Paykel DD24DCB6...
Ice maker not working. Fridge keeps beeping when opened
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Jan 31, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
Refrigerators Logo
57 people viewed this question
Top Fisher Refrigerators Experts
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
John Tripp
John Tripp
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
