Question about Electrolux Washing Machines
MY Electrolux EWF1074 washing machine is making noise and moving when it spins - looks like the outer rim has shifted- please help - thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
The tubs are usually hanging on springs or gas struts underneath. One of them could be broken or come loose. Col
Posted on Apr 26, 2017
  • 641 Answers
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
  • 19 Answers
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Posted on Nov 05, 2007
  • 51 Answers
SOURCE: Kenmore Washing Machine won't agitate, spin, or drain
The problem sounds like the motor to transmission coupler. If it is not draining or spinning you may find that the lid switch is inop.
Posted on Dec 07, 2007
  • 207 Answers
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Posted on Apr 11, 2008
SOURCE: electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
Posted on May 10, 2009
Electrolux EWF1074 washer stopped part way through the cycle & appears to have no power to it, but it does. Any suggestions please?
Is the machine draining, or attempting to drain? Pump could be seized or the outlet hoses blocked - or filter blocked, most likely. Could be electronics or motor too - but these usually give a fault code. Does it reset and pump empty? if no pump noise, remove filter and look inside at back - something stuck in there? ie hair grip, cotton bud, matchstick etc.
Oct 29, 2017 | Electrolux Washing Machines
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
Electrolux ewf1074
I am going to need a little more details of the problem
1. What did the big sound, sound like? was it a crashing noise and then silence or was there still a sound like something trying to move ?
2. Was it a small medium or large load laundry?
3. Have you tried using it after a while?
3.1 If yes please describe what happened when you started the machine again.
3.2 If no. Please try to start the machine without a load in it and describe what happens.
Apr 24, 2014 | Washing Machines
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
Electrolux EWF1074 7kg washer stuck on drain cycle
The first thing I would check is the drain line, not for a blockage but to see if the drain line isn't pushed down in the drain so far that its below the level of the pump. If it is you'll have a siphon effect going and the machine will never advance past rinse
Apr 26, 2012 | Electrolux Washing Machines
I want a manual for an electrolux ewf1074 front loader
Jan 03, 2010 | Electrolux Washing Machines
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
15+ year old Whirlpool top loading washer spin cycle broken.
Check the solenoid operation on the outer one that operates the spin bar. There are two solenoids that move back and forth all the time when running called wig wag solenoids. Check for broken wires and movement of the outer slide bar that shifts to make spin. It may need lubrication. Go to to get a diagram.
Apr 15, 2009 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
