Question about Pool & Spa
The spa has come up with thermal cut off see user guide?
    Scholar:
    New Friend:
  • 66 Answers
Water at the sensor has reached an unsafe tempurature. Check for proper water flow. There is usually a small button to push in to reset the sensor, it may be a red button the size of a pencil eraser or the same but behind a black rubber boot. Almost always located on the spa heater pack. Try removing the filter and running, if it continues to operate and heat, replace the filter. If not check the circulation pump for proper operation.
Posted on Apr 27, 2017
I have a Spek pool pump which keeps cutting out every 5 to 8 minute and then it comes back on after about two minutes. Very strange.
it it has a thermal over load , not strange at all
check the amps being drawn or replace the thermal overload unit
Jul 23, 2017 | Pool Pump Pool & Spa
How do I stop my pool pump from cutting out
Sounds like a thermal prolem. Is the fan plate on the motor? Are all the vanes free of obstruction, especially under the wiring box, once found a dead mouse under one on a pump that where the thermal cut out is usually located.
May 30, 2014 | Pentair 1.0 Hp Whisperflo Pump
Heater won't stay lit
could be caused by many things. could be an flame sensor error, open saftey switch, stack flue error, etc look on back of circuit board and tell me what errors are lit up
Mar 08, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
No power. The motor does not turn on
Most Dyson cleaners have a thermal cut-out to protect the motor from overheating in the event of a restriction to the airflow. So, if anything causes it to overheat, it will switch off. If this happens, leave the cleaner switched off for at least two hours, as it will not start again until it has cooled down.
The most common cause of a cut-out is that the cleaner has a blockage or the filter needs washing. A high room temperature may also trigger it. Before you continue vacuuming, ensure the filter is clean and there are no blockages. You can download the user guide at www.dyson.co.uk/support/. Just click on 'Get Expert Help' then 'Using my Dyson product' then 'User Guide'.
If this does not solve the issue you may have a bad switch or motor.
Aug 20, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Our pool/spa pump will cut off for approx. 20 minutes several times during an 8 hr cycle. It never use to do this. The pump is around 3 1/2 yrs. old.
If the motor is very hot it could be shutting off due to a thermal safety device.
Anything that makes the motor work too hard and/or heat up will trigger this.
Blockage in the water lines
Clogged pool filter
Worn motor bearings
Lack of air flow around the motor
Weak or damaged motor windings.
A defective thermal limit switch will **** off the pump when the pump is within heat and load limits.
May 22, 2011 | Sta Rite Sta - Rite 1/2hp Dura - Glas...
I have refilled spa and on turning on the display is saying Error 6
06: Heater Thermal Cut Out has failed. It means that the spa can overheat as the built-in protection is disabled.
Call your spa repairman for help...
Jan 24, 2010 | Computers & Internet
DOES THE DYSON ANIMAL HAVE A RESET BUTTON.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Most Dyson cleaners have a thermal cut-out to protect the motor from overheating in the event of a restriction to the airflow. So, if anything causes it to overheat, it will switch off. If this happens, leave the cleaner switched off for at least two hours, as it will not start again until it has cooled down.
The most common cause of a cut-out is that the cleaner has a blockage or the filter needs washing. A high room temperature may also trigger it. Before you continue vacuuming, ensure the filter is clean and there are no blockages. You can download the user guide at www.dyson.co.uk/support/. Just click on ‘Get Expert Help’ then ‘Using my Dyson product’ then ‘User Guide’.
Hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Dec 26, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson working one moment then it completely cuts out
Dec 24, 2009 | Dyson DC07 All Floors Bagless Upright...
Motor gets hot & the thermal cut-out shuts
one of the windigs in the stator has an open circuit
Nov 17, 2009 | Pool & Spa
Hot tub pump stops and control panel says there is a flo problem
Yes a pump does have a thermal cut out. When the motor gets too hot the thermal cut out will activate and the pump won't restart until the motor has cooled.
If you were an electrician, or highly confident/competent with electrics, you could test the motor with a volt meter. Run the spa and as soon as the pump stops running, check the voltage at the pump. If there is voltage at the pump, then the thermal cut out on the motor has activated. Do not try checking this yourself if you're not competent to do so.
You could also do the same test at the spa pack if it's easier to do so, just locate the output to the pump.
What spa and which spa pack have you got?
Cheers,
Ian.
Apr 24, 2017 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pool & Spa Logo
43 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
