I have some problem E7 error code means please Unit name Unix split 24000btu Any friends guide me please
  • 170 Answers
SOURCE: Leaks water from bottom of door. Error code E7 ?
I found this and it also may have to do with the door old is the unit...if door seals get old and stiff..(not soft and pliable) they sometimes leak...after usage the heat and moisture may cause them to swell and or become soft thereby sealing better...but this is what I found in the user manual.
Machine displays "E7" on LX30 model or "CLEAN PROBE" on LX40 model.
1. Clean water sensors inside tank.
It suggests contacting Hobart if this fails but I also found this problem is associated with fill in an E4 error...this what you do in that case....
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Good Luck and I hope this helps...let me know if it doesn't and i am sure I can get to the bottom of it...thanks for rating my effort...the Fang.
Posted on May 19, 2009
SOURCE: sharp ar-m205 error code E7 11
Posted on Jun 06, 2009
SOURCE: E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
Posted on Mar 19, 2010
  • 74 Answers
SOURCE: cannon pixma mp145 printer error code e7 & e2
E2: Reload the paper correctly and press [Black] or [Color].
E7: The cartridges are not installed in place.
These are from the manual.
Posted on May 10, 2010
  • 43 Answers
SOURCE: What does E7 Error code
?7 03 Problem related to the brightness of the laser emission 04 Error in determining the level of white in the performance of hatching 05 Error in determining the level of black during hatching 12 Error output level in the performance of hatching 14 Failure ASIC (MCU PWB) 15 Trouble copying lamps
Posted on Sep 20, 2010
What meaning of e7 error code on disply starway split airconditioner.
This is all I could find for E7 error code:
E7 Loss of 120 VAC power to all power module boards on the system. The system will shut down.
Look for tripped circuit breaker or tripped GFCI outlet. Any outlet wired downstream of GFCI (for example on same circuit as GFCI in bathroom) will lose power if bath GFCI is tripped.
May 13, 2017 | Miscellaneous
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
F8 error split air conditioner
F8 error isn't registered with my Daikin Airconditioner, though E7 showed up as a 'motor over-current' warning.
It might help if you find out the NAME and the MODEL NUMBER for your air conditioner.
Once you know this, then you can search for it like this...
Name - Model - error codes
E.g. 'Daikin Ft18k error codes'
Oct 06, 2014 | Computers & Internet
Code error E7
I'm not sure if NewAir is made by Gree -- they supply many. On Gree units, E7 simply means one unit is requesting heating while another is requesting cooling and you can't have both at the same time. So that's the first thing to check. Very simple, very common, doesn't indicate that anything is wrong with the system.
Apr 05, 2014 | NewAir ACS-1200H Split System Air...
E7 error message
The E-7 error code means the 2 wire defrost cable between the outdoor & indoor unit is disconnected or broken
Sep 10, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
This error is a communication error between your indoor and outdoor unit. You can try turning the breaker off for a few minutes and restart the unit. However if that does not work its best suggested to have an authorized HVAC technician service the unit.
Dec 24, 2009 | LG LS-L1210CL Mini Split Air Conditioner
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
