Question about Microwave Ovens
We are trying to buy garbage bins metal and preferably painted as the galvanised bins only last 3 - 4 months before rusting out. Do you have anything available please?
  • 38 Answers
SOURCE: microwave oven
THERE IS SPECIAL MWAVE CAVITY SPRAY .MAKE SURE YOU SANDPAPER IT THEN USE NORMAL PRIMA ALLOW TO DRY USE FINE SANDPAPER JUST TO MAKE SURFACE RIGID THE SPRAY
Posted on May 09, 2007
Arius
  • 446 Answers
SOURCE: magnetron antena metal cap hole due to spark
it is not safe to use this, DO NOT USE, repalace immediately, no need to repaint
Posted on Mar 22, 2009
SOURCE: my microwave oven has are rust spots;can I paint over them?
Yes, you can paint over the spots and no, it's not dangerous. I'd let the paint thoroughly dry before using the oven -- it could otherwise cause paint to buckle/ripple/etc.
Posted on May 03, 2009
  • 30 Answers
SOURCE: Can I paint rust spots w/enamel paint? Dangerous to use?
You will need to buy a appliance high heat paint. the spray can works the best.
AJIN G
  • 6694 Answers
SOURCE: Paint inside microwave is chipped and blistered. How do you fix it?
HI,
If you are able to spent money for a new Microwave then go for a new one.
If you are interested to repair and reuse the existing Microwave then keep on thing in mind, if you paint it then also it will not lasts for a long time as the metal underneath is rusted.
Ajin
Posted on Jul 15, 2012
HI,
Ajin
Jul 14, 2012 | GE Microwave Ovens
Inside my Daewoo KOR-6Q27 microwave oven, underneath rotating glass plate, white layer (or paint) have piled off and rust have started to emerge. Can this problem be fixed or i have to buy a new one? Was...
I have painted many Microwave oven cavities. You have to sand down the pealed off rusted areas and completely clean and degrease. Before painting, I use laquer thinner as a cleaner degreaser. Fumes can be a bit strong but it has worked well of me. I normally buy an automotive spray paint. They have a lot of different colors and a lot of the import colors can really come close to the color inside the microwave. Spray on thin layers till you get good coverage and make sure you let it dry thoroughly before trying to use. The paint in a Microwave isi not a special microwave energy protective paint. it is only there to make it look pretty and protect the metal. So a good automotive paint normally works fine.
Sep 25, 2017 | Daewoo Microwave Ovens
Bottom is rusted in underneath the little wheels
You can buy apliance spray paint, but sand it down clean first before spray painting it so the paint will adhere well to the surface.
Nov 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
On the bottom of my microwave, the coating started "chipping" off and now there is a fairly large area that appears to be rusting and makes where the turntable wheels rest look really dirty. Is there...
This is often caused by spills and condensation.
The metal will have to be sanded smooth and clean.
You can use a wire brush and naval jelly to get rid of the rust.
If any rust remains, you can use Rust Reformer paint to stop the rust process, then sand it smooth when it's dry.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
Nov 23, 2009 | Emerson Microwave Ovens
Hello i have a problem with my microwave I used an abrasive cleaner on bottom of microwave under the turntable it has now started to rust at this stage surface rust only is it repairable
Yes you can, it is a painted surface correct? If so buy some rust inhibitor spay or primer and spary the bottom and then paint. Make sure you tape off any vents on the bottom before you do anything
Oct 01, 2009 | Microwave Ovens
May 03, 2009 | Microwave Ovens
Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Mar 25, 2009 | Sharp R-820B Convection/Microwave Oven
Enamel under the glass turntable has flaked off
This is due to spills, accumulated moisture from steam / condensation, or both.
It can also be worse if your internal cooling fan is not running, or if the vents or filters are blocked or clogged.
Since the the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and then dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Let it dry overnight with the microwave door open.
Once that's done, you should occasionally look for accumulated moisture on the floor of the oven and keep it dry.
The model number tag should tell you where it was made.
Jan 07, 2009 | Magic Chef MCB780W Microwave Oven
Rust inside the microwave.
The areas can be sanded and painted, but first make sure there are no holes rusted through. If it's all surface rust, then sand and clean as best as you can. If you have any areas rusted through - get rid of the microwave.
Use the paint sparingly - don't try to cover in one or two coats. Best results are obtained with very, very light coats drying 10 minutes or so (depending on the humidity) in between. 10- 15 coats usually works well.
It's best to do this outside, as you'll have lots of overspray.
As far as the paint - the best I've used for the last 20 years or so comes from A.M.I. Parts. You can find them @ www.amiparts.com or toll free 1-800-522-1264.
Jul 04, 2008 | Magic Chef CMV1000B Microwave Oven
GE microwave
If the mocrowave still working, I wouldn't worry about operating it. If you want to have some peace of mind you can buy the paint and do it yourself. Go HERE to get the paint that is specially for microwaves use.
Feb 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
