When i wash my windscreen the smell that comes through my car is terrible what can it be
  • 30 Answers
SOURCE: Terrible Smell
Try a Quarter cup of dish washer detergent and a hot wash. this will flush out the inner bowl. Make sure you use the powder only and watch for over foaming. You might be getting a funny smell from the fabric conditioner.This stuff forms badly to the side of the bowls like glue. You couild take the bowl to pump hose off and clean the system out including the pump making sure you unplug the washing machine first. I would personally flush it out two or three times first. steve NZL, keep it simple
Posted on Jan 05, 2007
  • 20 Answers
SOURCE: I have a Renault 225
Are you sure the smell comes from the washer water and not the air conditioner? If the washer water smells you will smell it strongest on the windscreen on the outside of the car. Check this to be sure you have located the source of the smell.
Commonly smells inside the car come from the air conditioner because there is mould growing on the air filters. These can be taken out and cleaned to get rid of the smell. Look in your user manual for guidance on how to do it.
Posted on Oct 10, 2008
  • 2976 Answers
SOURCE: As i wash my car front windscreen,water runs into
The drains in the gutters under the hood are clogged. Straighten out a wire coat hanker and push it down to break up the clog. Road dirt, dust, traction material & leaves & pine needles will form a plug very fast.
Posted on Apr 24, 2009
  • 32 Answers
SOURCE: Windscreen wash full, motor runs but little coming out of jets.
This may be because the motor employed for squirting the water is not functioning.Also check if the nozzle spraying the solution is not stuck.Insert a small pin into the nozzle and clean off any dirt stuck in it.Also the position of the nozzle can be adjusted by rotating the pin after insertin the pin into the nozzle.Also Check the pipe inside the reservoir if any dirt is stuck inside.also at times the the pipe connecting to the nozzle just under the bonnet may be loose or unconnected.So check all these.
Posted on Sep 28, 2009
  • 193 Answers
SOURCE: How do I remove a terrible mouldy smell coming from the washing machine?
fill machine with water then use 1 bottle of apple cyder vinegar then let it sit 1/2 hour then put through 2 full cycles (warm water)
Posted on Dec 18, 2014
Heater steams up all glass on inside of car
pop the bonnet(hood) right under the windscreen rubbers you will see a blavck plastic box about 3feet wide,clean out the drain under the fan unit,it is blocked with s...
Apr 26, 2010 | 1992 Audi 100
Smelly top loader. It stinks. The clothes don't smell, though. The smell is coming from between the porcelain bowl and the metal exterior. It realy smells terrible. I've run 2 loads of hot water with...
Bacteriological action is becoming more of a problem nowadays due to low temperature washing , the deteregents , wash your clothes well but do not kill off bacteria , this is generally harmless to us but can build up in your machine , giving rise to a smell and sometimes a slime which can get on your washing. A regime of High temperature washes WITH NO CLOTHES IN MACHINE , just a dose of bio-powder every six to eight weeks , may help.
Nov 08, 2009 | Washing Machines
Terrible smell from the washer. This is a new
do not use baking soda this will react with your detergent and leave smelly deposits and reduce the wash performance modern good quality detergents contain everything needed for a good wash result and a sweet smelling machine. try a hot wash with detergent and an empty load to get rid of smell.
Nov 07, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Mymachine smells terrible all the time. What can I
TRY RUNNING A LOAD WITH A HIGH CONCENTRATION OF BLEACH THE SMELL IS PROBABLY A BACTERIA OF SOME SORT
Aug 13, 2009 | Maytag Washing Machines
Terrible smell coming from washer while in rinse mode.
This is classic bad design actually.
Some washers are worse than others for this.
Use an oxygen based bleach in a trigger spray, and remove the detergent drawer. Use the spray everywhere in there - and remove the drawer completely to wash it in a mild bleach solution.
Use a small brush to remove the mould in there - and flush it down the pipe with more spray.
If you an get a foaming cleanser down there - then even better - or an alcohol based sanitiser spray.
Also wipe over the door seal rubber - as this sometimes collects stagnant water in the folds.
Reassemble, and do a hot wash with a few white hand towels to remove all the bleach.
You may need to do this every month.
Doing hot washes helps - maybe with a cap of bleach.
(I think the manufacturers do this on purpose - so you wash more often - breaks machines - you buy a new one etc.)
Aug 06, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a Renault 225 sport cup. The problem I have is with the water bottle for the washers. This has been smelling really badly for some weeks and when I spray the windscreen the smell inside the car is...
Jul 08, 2008 | 1986 Renault Sport
Terrible smell in washing machine
I used white vinegar in the machine and did a full wash.
I am subsequently not using a softener in the machine as I have found out that this is what caused the smell.
I now use white vinegar instead of softener and this has solved the problem.
Jul 01, 2008 | Washing Machines
Terrible Smell
Jan 04, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
