Can i report to you on here that i am going over seas
My super tenere XTZ 750 runs pooorly at high altitude
late model EFI controlled engine ,indicates a Baro slate model EFI controlled engine ,indicates a Baro ensor problem not reporting to the ECM to adjust for less air
Take it in for a fault code check
if carbies it could be a float level problem and a air/fuel mixture adjustment or jet sizing problem
Feb 28, 2018 | Yamaha Sidewinder Twin Tech Generator...
ECM location for 96 Hyndai Accent
It is located just above the fuse box behind the dash at the driver footwell.
Any further help, let me know.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
May 08, 2009 | 1996 Hyundai Accent
I need a water filter for a msd2655 maytag.Which one should I use?
Your model requires the=> PuriClean II Model UKF8001AXX
Here is the page from the Service Manual=> PuriClean II Model UKF8001AXX
Should you require a user manual or Service Manual User Manuals Click Here=> Maytag User Manuals I was going to link your user manual but the site is down and has been reported automatically. And if you have other questions please ask me here at Fixya, Thanks, Sea Breeze
Apr 12, 2011 | Maytag MSD2655HE Side by Side Refrigerator
I have got a dell inspiron laptop..bought just two months back.. when ever i start my laptop an alert message pops up 'Hard disk problem is preventing the windows to start '.
If the computer is under warranty then contact the dealer -manufacturer first-
If not you can use another computer to download a program called sea-tools - burn this to a cd disc - start your computer then go into set-up-usually by holding delete button or some times f2 change your start up boot sequence so your c/d -dvd rom boots first --insert the cd into your cd drive then restart the computer --once the computer boots from the cd follow the prompts from the sea tools program it will run a couple of checks and give you a hard drive report it will also attempt to repair your drive it it can .
I hope this helps
Andrew
Mar 26, 2011 | Computers & Internet
2004. Nissan. Maxima. Check engine light code 1283
P1283 - lean condition pre-cat
A lot of Nissan's are having this problem especially the Z's and the Infinity G35. A few people have reported changing their PCV valve which will be in the top of your valve cover and goes to the intake.
Mechanics report that there are 2 oxygen sensors after the cat converter that it could be, and also run a bottle of Sea Foam through to clean your injectors. You will still have to go to Advance or Auto Zone to have it reset, but either way I would try the Sea Foam and the PCV valve first since thats really easy.
Mar 07, 2011 | 2004 Nissan Maxima
As i put my foot on the acc, in all 5 gears, sometimes it judgers like a kangaroo, like its running out of gas
OK number of possibilities here- Im gonna give you the most common ones-
a dirty fuel filter can cause vehicle sputter by blocking the flow of gas from the pump to the engine
a dirty air filter restricts air flow causeing the MAF (mass airflow censor) to report abnormal readings to the ecm (computer) causing the ecm to adjust fuel mix improperly resulting in stutter
bad plugs, wires, or coil - if the engine cant achieve proper spark it will hesitate.
Sounds like you need a tune up- Id check your fuel filter first and go from there, buy plugs before you buy wires, and wires before you buy coils-
Feb 03, 2011 | 1999 Volkswagen Passat
I'VE BEEN PUT ON EXTENDED HOLD AND EASTGATE SEA...
Get a speaker phone so you can go about other tasks while you are on hold. File a BBB report against them.
May 20, 2010 | Garden
Hi, my name is Alan,I have a 1990 Pontiac Grand Prix 3.1v6. A few months ago I changed the spark plugs, Fuel filter & ran some Sea Foam through the tank. Recently the car has been idleing rough &...
If the car ran good before you put that sea foam in the tank, there's your problem. I haven't heard one good report about that junk, some swear by it, I've always used that techron injection cleaner, and never had any complaints.
Jul 14, 2009 | 1990 Pontiac Grand Prix
Sea Map & Crest
when you get to this part open the southwest sea map on your bottom screen (so you have the gray sea map on the top and your sea map on the bottom screen) now close your DS and than open it again now the crest will be transfered onto your map. go see Lineback after that.
Feb 03, 2009 | Nintendo The Legend of Zelda: Phantom...
$4900 has not been credited into my Visa Account
sounds to me like you been scamed im sorry
Dec 16, 2008 | PayPal Accounts
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
