Question about HP Cell Phones
I purchased a Tohatsu 30 hp outboard on the 18/9/2015 with 3 year warranty,Due to ill health the motor 1st time in salt water on the 23/4/2017 i noticed surface rust on the leg {no warranty)
Cohoe Marine Phone 9519 3575 My Name Bill Deska Mobile 0412 932 726 22 Rowley Place Airds 2560
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
SOURCE: 30 hp johnson outboard motor trys to start. It
1985 30 hp johnson used a cdi system(solid state, no points) check the power pack.
Posted on Mar 09, 2010
  • 23 Answers
SOURCE: do you have a wiring diagram for an MP39760 marine
Seloc has the best manual.
Posted on Mar 23, 2010
  • 91 Answers
SOURCE: suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Posted on Jun 20, 2010
SOURCE: how to replace water pump on a 1985 90 hp mariner
water pump replace
Posted on Mar 30, 2011
Should there be any moisture coming from the exhaust of my 4 Stroke Tahatsu outboard
Yes, gasoline contains water at molecular level, so when it burns you get steam which then condenses. Although I don't know your engine specifically, all marine engines that I have had, have coolant water which is pumped around the engine, some is vented out through a hole that is visible to the driver, so you know the cooling pump is working and the rest is vented out of the exhaust.
You can see water on the top image on their website.
https://www.tohatsu.com/outboards
https://www.tohatsu.com/outboards/20_4st.html
Apr 30, 2018 | Boating
To extend leg 6 inches on a tohatsu 90 hp m90a boat motor do i replace the drive sharft or put an exta ension n
fit a longer leg section to the power head
talk with a tohatsu service agent for the longer leg
Dec 28, 2017 | HP Boating
I changed the gear oil on my 3.5 tohatsu outboard propeller and the propeller wont run after I changed the gear oil, why?
Was gear oil milky, or water and oil separate? Do you use in fresh or salt water?
Sep 20, 2017 | Boating
What year is Tohatsu M15B2 serial number 351A33838 outboard
Hi!
You can contact Tohatsu directly using the form provided at the link below.
Hope this helps,
-Steve
http://www.tohatsu.com/contact/wiz_modelyear.html
Aug 06, 2014 | Raymarine St6002 Smartpilot Hydraulic...
I have a pair of 50 hp Tohatsu (TLDI)outboards with with system issues...when I try to fire them up pressure builds and forces gas out the hose connection just past pressure pump...solution?
Sorry no idea without a play but i would suspect that the pipes are old and porous ,this happens with cars a lot and these engines are no doubt used in salt water so this would shorten the life of the hoses
Jul 07, 2013 | Boating
Have new tohatsu outboard that runs fine but wont rev out over 4500 rpm
I just looked at 7 different sites and they are saying Max RPM is between 4,500 - 5,050... How accurate is your Gauge?
Prop Pitch will greatly effect MAX RPM.
Apr 05, 2013 | Sierra International 18-6431 Marine...
MY GE WATER SOFTENER QUIT WORKING PROPERLY AFTER 6 MONTHS ,I HAVE HAD SERVICE CALLS AT $150 EACH TO NO AVAIL IT DRAWS SALT BRINE MY WATER HARDNESS IS 17 I HAVE SOFTENER SET TO 22 .I HAVE PRE WATER...
What is it doing? No soft water? What is the water analysis? Try manually regenerating 2x in same day. Make sure a bypass valve is NOT open. I need more info to help.
H2O Services
Jan 17, 2011 | GE 30000 Grain Water Softener GXSF30H
Cell Phones Logo
22 people viewed this question
Top HP Cell Phones Experts
D. E. Hev
Andrew Taylor
Andrew Taylor
richie46
Are you a HP Cell Phone Expert? Answer questions, earn points and help others
