I cannot do printing with 2550 ricoh. error code 819 will display. but photo copy can be done.
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
munybuny
  • 14 Answers
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
  • 990 Answers
SOURCE: Error 52 on ricoh FT3213.
error code 52 on ricoh ft3213, that's mean heating element burn out , such as heater lamp, thermister , thermo fuse.
Posted on Dec 10, 2008
  • 393 Answers
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Posted on Jun 18, 2009
santosj27
  • 263 Answers
SOURCE: Error SC 551 / Ricoh
Hello!
This code is related to a Fusing temperature error.
You probably need to take a look at the heating roller thermistor.
The best advise i can give you is to call a technician to see it (if you do not have technical knowledge)
If you want to reset the code try this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Press "copy SP"
On the key pas press 5810 and #.
On the touch panel press "execute"
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Posted on Aug 04, 2011
Ricoh aficio 2550 code error SC411
Ricoh Aficio 250 Error Codes
Code
SC411
Description
Separation bias error
A separation bias leak signal is detected.
Causes
• High voltage supply board defective • Poor connection of the PCU • Discharge brush defective
Apr 10, 2017 | Ricoh Office Equipment & Supplies
My machine ricoh mp c2352sp displays SC 819. I can't enter to maintenance mode and it couldn't accept the firmware. Any help to solve it!
You have a bad print job coming in... You can prove it by disconnecting the ethernet cable from the unit and reboot the copier, (cancel the print job, that most likley was printed from the internet) -Carl
Dec 08, 2015 | Ricoh Office Equipment & Supplies
Error code SC 565 Ricoh MP 2550
SC565
*Heat lamp consecutive on error - Broken main fuser connection
*Heat lamp consecutive on error - Check HR thermistors with SP1-106 001 (ctr) and 002 (ends)
*Heat lamp consecutive on error - Heat roller lamp defective
*Heat lamp consecutive on error - Power Supply defective
Mar 11, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
Service Call SC819
I found that this 'SC 819' occurs if you use the bypass tray for the scanner. I found also that this error can be fixed with an firmware update. See link. http://www.copytechnet.com/forums/showthread.php/32934-Ricoh-Aficio-2035-SC819-Error-Code?p=132762&viewfull=1#post132762
I have no idea how to do that at the moment, and I can't report the success of this way.
Jan 22, 2014 | Ricoh Aficio SP C240SF
MPC 2550. What is error code sc 865 01?
SC865 (HDD access error) is displayed when the power is turned ON, and SC819 (kernel stopped) is displayed when the power is turned OFF and ON.
Some broken files may be left in the HDD image disk space.
Repair by initializing the HDD image disk space (SP5-832-002).
Dec 17, 2012 | Ricoh Office Equipment & Supplies
Richo error code sc 829
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
Apr 05, 2012 | Ricoh Aficio 1035 Copier
Error SC 551 / Ricoh MP C 2550
Hello!
Press yellow key
Press "copy SP"
Hope this helps you
Aug 04, 2011 | Ricoh Aficio 1013F Copier
Ricoh copier 3813 - error e
E codes are displayed in the copy counter.To display both digits of the E code press the enter key.
E11 exposure lamp error.Possible causes exposure lamp open thermofuse open.
E12 exposure lamp error Ac drive board defective or main board defective.
Oct 26, 2009 | Ricoh Aficio 450 Copier
k24674
