Question about Vizio Televison & Video
My vizio TV won't change channels or let me pull menu up what do I do?
    Scholar:
    New Friend:
  • 56 Answers
Try universal remote
Posted on Apr 26, 2017
Vizio tv says no signal
you should be able to do that with the remote by pushing "03"
or with manual buttons in menu under tuning selections , add channel 03
Apr 15, 2014 | Televison & Video
Tv channel problem
set your TV! go to menu then click auto search!
Oct 05, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Tip
Vizio Factory Menu
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV. Here's how to access the menu: 1. Hold down the CH+ (Channel Up) and the CH- (Channel Down) buttons on the TV. 2. While holding these buttons press the power button on the TV. 3. After the TV comes on, let go of the buttons, and enter the TV menu as usual. 4. You should now see a "F" in the lower right hand corner of the menu. (If not please repeat steps 1-3) 5. Hold down the menu button on your remote and the Factory Settings menu should appear. From this point you can tweak whatever settings you wish. *CAUTION* - Make sure that before you do anything you write down the settings before you change them. I have seen it mentioned that certain settings never be adjusted. Please search the internet regarding your problem before you do anything. A good resource is www.avsforum.com
on Jun 27, 2007 | Vizio L32 32 in. LCD HDTV
Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Dec 17, 2012 | Vizio RazorLED M260VA 26" LED-LCD TV -...
Vizio vm60p hdtv scanning problem
I had the same problem. Change your input to dtv even if you are using coaxial input. Then go to the menu screen and select tuner settings. Dtv setting should appear.
Nov 17, 2011 | Vizio VM60P 60 in. Plasma TV
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
No sound after I change the channel. If I turn the
There is an incompatibility between Fios and Vizio audio. To fix the problem, on the Fios box, press "Power" then "Select" then "Menu", one right after the other. This accesses a secret menu on the Fios box. Using the arrow keys on the front of your Fios box, arrow down to "Additional HDMI Settings" then press the right arrow. Another menu will appear (may take a few seconds). Arrow down to "Audio Out" and press the right arrow to change from "Auto" to "L-PCM". Press the Power button to exit the menu. This should solve your problem. Thanks to Vizio tech support for the answer.
Apr 29, 2010 | Vizio L37 Television
Ch setup on a vizio tv.
( FOR VIZIO TV MODEL VO47L )
Press menu on the remote,
then go to the icon that says TV,
then press down on the remote to change,
"Tuner Mode" for Cable or Antenna.
"Auto Search" for auto search channels
"Skip Channels" for removing the unwanted channels.
If you need a copy of your manual, go here:
http://www.vizio.com/downloads.aspx
May 23, 2009 | Vizio VO47L 47 in. LCD TV
CHANGE CHANNELS WITH THE CONTROL
Run a channel scan on the DTV and/or TV input depending on what one your not getting channels on. This will solve your issue.
Change the input on the unit to the DTV or TV input. Press the menu button on the remote. Navigate to the tuner DTV or TV tuner setup menu. Go down to auto search using the down arrow. go right when with auto search selected. This may take a few minutes but you should have all the channels back after the scan.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
My Vizio plasma TV won't change channels with the remote or side buttons, but if I input a channel number, it will change that way.
Try unplugging the TV for a few minutes and then doing an auto channel search through the menu button. That has solved my problem, at least for the time being.
Aug 11, 2008 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
