Question about LG Refrigerators
My lg refrigerator has a 175 volt compressor .when it's working it's not cooling at all and there is just 110 volt coming for compressor.
  • deton8 von Splosion Apr 26, 2017
    Greetings & salutations Hoosik Safarian,
    YOU are going to have to give some better clues.. Country... Line voltage.. Perhaps even model number...
    This is a global site... (pretty please)
    Edit your question to help your helpers.
  • 150 Answers
SOURCE: need to convert my 110 volt 15amp to 240 volt
You can buy a transformer which allows all 110v power tools to work from a 240v supply. You will also need to change the plug on the compressor to a yellow 110v type. You can buy transformers for around £25 and around £3 for the plug
Posted on Mar 29, 2009
AZBen
  • 194 Answers
SOURCE: compressor working, cooling coils hot, but unit won't cool below
When you say fully charged, did you weigh the refrigerant? These small systems cannot tolerate overcharging by even small amounts because it will result in overpressure on the suction side. If there's too much refrigerant you get hot coils and cool but not cold evaporator. I typically pump the refrigerant into a recovery tank and then weigh it back in to get exactly the amount on the mfg label.
Posted on Dec 12, 2009
c7121
  • 160 Answers
SOURCE: how do i change my century 2hp electric motor on
ASSUMING U HAVE 4 WIRES; 2-110V, 1-GROUND, 1-NEUTRAL. REMOVE AND OR DISCONNECT 1 OF THE 110V WIRES. IT STILL MAY NOT WORK PROPERLY BECAUSE U NOW JUST HALVED ALL THE VALUES; AMPS, OHMS, ETC.....CONSULT AN ELECTRICIAN 1ST.
Posted on Dec 13, 2009
  • 161 Answers
SOURCE: LG refrigerator compressor/lights won't turn on
You have a bad main board call LG service and discuss your options.
Posted on Jan 24, 2010
  • 256 Answers
SOURCE: ice on top of compressor
You may have a slow refrigerant leak or too much refrigerant in the system. Contact an appliance service company.
Posted on Feb 26, 2010
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Maytag refrigerator not cooling
HI,
You have a new design cooling system the runs on a 230 inverter with a DC compressor. So Check the red and black wire to the inverter for 110 volts or better to it. If you have this voltage, replace the inverter only as it has failed to run the compressor. I hope this helped. Parts number is W10285954, this is not a cheap part but controls the compressor run. Good Luck
Aug 31, 2014 | Maytag MFT2771WEM
LG Refrigerator GR2211GDC. Compressor was
Whoever replaced the compressor obviously left a leaking solder joint. That needs to be fixed, after which the unit needs to be recharged.
May 26, 2011 | LG LRSC26980 Refrigerator
GE profile refrigerator model # PDS22SCRRS not cooling. I looked in the back and condensor fan is not working. Should I assume that it needs a new motor or is it possibly the motherboard which I have read...
Check to see if you have 110 volts at the motor with the compressor running. If you do then your motor is bad - replace it. Also make sure something has not gotten in the fan to keep it from working. The fan must run to keep the compressor cool and from over heating. Be sure to put the back of the refrigerator back on when you are through.
Jul 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Fribge not cooling
ok but is the compressor running can u feel the black bulb like object working at all if its not working then you have a start relay problem if it is working then im sorry to say you have a compressor problem hope this helps usally not economically feasible to repair the compressor unless you have a freind of a freind most compressor repair people get on the cheaper side 150-175 just for labor and then you still have to add in the cost of the compressor might be time for a new fridge or calling that freind of a freind
Jul 13, 2010 | Amana ARS266ZBS Side by Side Refrigerator
It started clicking today and now it won't cool. I hear it running and the lights still come on but its getting warm in there. It is only 7 years old. it is a freezer on top brand, not one of the recalled...
try a hard start kit it has an electronic start instead of mechanical and has a large start capacitor to give an extra punch to get it going if it is stuck i put240 volts just to the compressor for just for a sec do not hook to the 110 volt plug....compressor only unhook the wires that come from the fridge to the compressor switch polarity back and forth
Aug 27, 2009 | Refrigerators
The refrigerator stop working, when we plug the refrigerator into the wall it does not come on and it trips the circuit breaker.
Aug 22, 2009 | Refrigerators
Freezer stoped cooling
Check the relay on the compressor. It sounds like the relay is not kicking on the Compressor like it shorted out. You can check it with a multi meter, it should be 110 volts or more if there is less or if you see a burn mark replace it. They are about 30 dollars at a local appliance shop
Apr 17, 2009 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
97 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
