Watches Logo
John Mobley Posted on Apr 26, 2017
What battery size does my fossil fs4283 take - Fossil Watches
Battery for fossil blu ch-2495
Fossil battery replacement sizes are usually a 2430 (CR2430), 371 (SR920SW), or 377 (SR626SW).
https://www.fossil.com/en-us/******/how-to-change-a-watch-battery
Which battery does a Fossil Big Tic JR-9779 (Chinese Dragon)watch take
Fossil Watch Battery Replacement - Ultimate Size Guide -
batterymole.com https://batterymole.com > fossil-watch-battery-replace...
Aug 21, 2022 - The CR2430 battery is a 3v lithium battery, see the shape below. This example is made by Renata, but you can also get the produced by Duracell, ...
I am trying to find out what size battery is used in the fossil fs4775 watch...
Take it to a watch specialist who will open the case and be able to measure the battery compartments dimensions to specify the required battery and replace it for you.
2helpful
Bought a fossil FS-4283 came with no users manual!!!
Hi. Follow the link to get the manual your looking for to your new watch.
http://www.retrevo.com/s/Fossil-FS4283-Watches-review-manual/id/22194dj989/t/1-2/
Battary size for fossil blue watch bq8775
Thanks for contacting Fossil.
The only way to know the battery size is to pull out the old one. It might also be in your manual. It might be on the outside of the watch.
If battery is missing, then you will have to measure the cavity and match it against a battery chart.
Best wishes.
1helpful
My Fossil FS4283 had been working fine since the time I bought it in 1997. It stopped working suddenly a couple of days ago and no matter what I do doesn't start back. It doesn't have a battery and charges...
mcdevito75 here, Sounds like the chargeing system has gone bad in your Fossil watch, Best Bet look for a small watch repair shop in your area, have them take a look at thr watch.
Jul 02, 2010 • Watches
1helpful
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
