Question about The Health & Beauty
I have a friend that dropped his Fuzion T-200 digital pocket scales . Now the display just reads 0.00 unless you apply pressure with your finger. How do I fix this problem?
    Master:
  • The Master
  • 923 Answers
Get a new one ... but NEVER drop it or bump it!
Posted on Apr 26, 2017
Pocket scales read hhh turn
Try this - While it is off, press and hold both the mode and the tare* keys at the same time and press the On/Off key - Release the keys and observe the display - cycle through a series of numbers. Press the mode key once and observe the display "CAL 0" "100.00" then similar numbers as before. This step calibrates
Check here - http://wiki.answers.com/Q/How_do_you_calibrate_digi_weigh_scale_DW-100AX_or_fix_errors_such_as_F--H_or_ERR?#slide=1
Apr 12, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Fuzion RT500 professional digital mini scale user manual
Starting with the unit off. Press the power button and hold down until it starts to cycle through the weights.
Feb 07, 2013 | Health & Beauty
How to fix an easy weigh digital scale
the 24c02 is a memory chip inside. Unless your a tech - you can't repair.
Jun 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Find fuzion digital scales fz-75 instruction manual
I have written reviews on GE HDTV antenna, please read this http://usemyreviews.com/ge-24769-outdoor-antenna-digital-hdtv-futura/ GE 24769 Outdoor Antenna for Digital HDTV Futura
Jun 05, 2012 | Office Equipment & Supplies
DigiWeigh pocket scale showing..UnSE code..what is UnSE code?
Remove the battery - this happens when the scale tries to use a dead battery instead of the wall power supply.
May 02, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
How to set GDT-311 Digital Multimeter to x 1000 ohm setting?
The 20K setting is close to what you're looking for. The 200 scale is best to read 0 to 200 ohms, the 2K setting would be to read 200 to 2K, the 20K is to read 2K to 20K, the 200k range is for 20K to 200K and finally, the 2000K is to read 200K to 2000K or (2M) ohm resistance.
Basically, start on the high range, and work your way down until there is only one (or none) digit after the decimal point in the display for the best accuracy. A 6,500 ohm value may display as .006 reading on the 2000K range, and as you can see, doesn't give a true reading of the actual value.
I hope this helps!
Apr 12, 2012 | Gardner Bender Measuring Tools & Sensors
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
Health & Beauty Logo
66 people viewed this question
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
