I just turned on my wega machine I just bought (second hand) and all of the lights are flashing. What does this mean and how do I stop it? Thank you
SOURCE: Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Posted on Jan 05, 2008
  • 4 Answers
SOURCE: sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Posted on Aug 31, 2008
  • 1039 Answers
SOURCE: Power Light Flashing Red
Change the lamp. If red led is flashing 4 times. replace lamp fan.
Posted on Apr 25, 2009
rylee_smith
  • 8619 Answers
SOURCE: Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 01, 2009
SOURCE: When the bike is off, a yellow light is flashing
I downloaded the users manual off the internet.
The flashing light is the immobiliser which flashes for 48 hours once the bike is switched off.
Posted on Oct 13, 2009
HOW TO FIX: CHECK LIGHT & O/D LIGHT FLASHING -Won't go off!
You mean engine light is on,turn three times the on and off do not start car,should flash light...two times =2-3 means code 24
Dec 03, 2015 | 1994 Toyota Camry
RED LIGHT FLASHES ABOUT 5 TO 10 SECONDS AFTER THE TV IS TURNS ON A SONY WEGA KDF 55E2000
I can safely say that the components are still in good working order, just because it's flashing doesn't necisarily mean the components are ruined, but i can see how it's distracting, my suggestion either paint over the defective led
May 29, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Just bought a second hand guitar, turns on lights
Have your synchronized the controller to the xbox? To do this, there is a button on the front of the xbox and one usually on the bottom of the guitar hero controller. hold both of these buttons, the lights will circle then when its synced they should stop and resume being player indicators. If this doesn't work, return the guitar to the shop you bought it from.
Dec 26, 2009 | Activision Guitar Hero III: Legends of...
Sony grand wega turns off & o ever 30sec flashes green light
it's a power failure.try to replace the regulator in power supply board.
Sep 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron wega 36 inch
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
KDF-E60A20
do this for me turn off tv hit the follow hit this button display,5,vol down, power and till me the error code for this set this a have a
cpu in them ever time the led blink on front of set that mean thear is some pu with tv. so chech it and git back to me with code
thank you. bob..
Jun 12, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KF-WE50
how i can do this.?
Jan 05, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
Top Televison & Video Experts
