Question about Watches
Fixing Ronson Varaflame whirlwind lighter
Need assistance on how to properly clean or tune up ronson lighter that has been not used in 30 years and how to fill it with butane and how to put flints in
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: refilling a dunhill lighter
All rechargeable lighters have a refilling nozzle (usually at the bottom of lighter).
All the good quality gas refill cans have the nozzle adapters inside sovering cup.
Brake off the nozzle adapters off the cup and try to fit them onto lighters refilling nozzle.
When found the best fit adapter, put it onto gas refill cans nozzle and holding the lighter and can upside down connect all nozzles together and push together.
As these nozzles are made for mass production lighters, tey do not fit perfect and some gas leak will occure.
Anyway- few seconds will be enough to refill any lighter.
In case if your lighter do not refill by explained action, the refill nozzle in your lighter is damaged or faulty.
Hope it does help.
Do not forget to rate, please.
Posted on Jan 23, 2009
intower18
  • 957 Answers
SOURCE: ronson 9048 serial no. N16218
Please go to this site below so that you will be able to get the manual guide for your oven.
http://www.manualsnguides.com/search.php
Just copy and paste it to your internet browser so that you will be directed to the exact site.
I hope you have a great day..
Posted on Jul 16, 2011
Cartier lighter- doesn't hold the flame. Major problem? Thank you.
Anon, Check the attached links,instruction and guides to trouble shoot lighter problems. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.cartier.com/services/expertise-guide/care-recommendations/care-recommendations-lighters/flame-adjustment-screw-566.html
Quick Tips on Getting Your Lighters Working Again
How to Troubleshoot Lighter
Fixing that jet lighter you love
May 17, 2016 | Cartier Watches
Bulova mantel clock won't keep time. New batteries and will chime. It's about 25 years old at least.
Try CAREFULLY cleaning the mechanism with naphtha lighter fluid. Lighter fluid is high grade naphtha. Be careful not to allow it to run on to the face and electronics. It may damage the face with stain or remove any decals or cemented numerals. It may only take a small amount to clean the shaft bearings. The lighter fluid cleans and lubricates without leaving a film. If you can, while the fluid is on the gears, manually turn the clock forward 12 hours. That will rotate all the gears fully. Us the fluid sparingly!
Apr 14, 2011 | Bulova Watches
I have a gold Dunhill lighter which belonged to my partner who passed away a few years ago. Whilst he was still alive I sent the lighter away to be cleaned etc, the shop I sent it through has now closed...
If you go to their web site http://www.dunhill.com/en-cn/catalogue/lighters/ at the bottom of the page you will see find a service center and find a store.
Click on one of these and you should be able to find the information you want.
Apr 04, 2011 | Dunhill Watches
I have a cigarette lighter from the 2000 Olympic games but it will not spark. Can you help? Kym
Thanks for contacting FixYa.
First check your fuses. If that isn't the problem try this: take a small flat head screw driver and gently bend the two prongs out a little bit. They are used to hold the lighter in place so that it will operate properly. If your lighter works with the key off remove the fuse first. As for replacing the lighter there are two wires connected on the back side you'll need to remove them. On some lighters you will have to unscrew the outer body to remove the lighter others have a nut that has to be removed. Access to the back side of the lighter is always a pain and how you gain access depends on the make, model and year. I hope this helps you.
Sep 02, 2010 | Watches
Got my wife's salt water damaged timex heart rate monitor watch here. Opened it up, and one corner of the screen looks a bit faded and there's white corrosion mess. Can I dip in metho to clean away residue...
Do not use any chemicals. They will damage your watch. The only thing you can use is ZIPPO, RONSON e.t.c. lighter fluid, but do not dip any watch parts in it. You have to use cotton swabs. Dip the swab in lighter fluid and then clean the parts. Do not use a lot of pressure. Change the swabs constantly and blow off excess of lighter fluid all the time. It will take a while, but this is the best solution. When part is clean enough, use dry cotton swabs to clean off the oily residue. Rate me, plz.
Feb 09, 2010 | Timex Rush Sports Watch
Fixing a dunhill lighter with a small leak, can I pack this or do I need to take this in to a shop? many thanks, Jayson
I have a Dunhill Rollalite petro lighter and the wick is barely protruding out of the nipple / port. Everything thing I've read states to use tweezers to extend it but how is it done when there's nothing to crab? Are the wick replaceable and if so how is it done port how to extend it? Thanks
Feb 08, 2010 | Dunhill Facet DQV911AL Wrist Watch
WHERE CAN I GET A RESERVOIR FOR MY CARTIER LIGHTER
The reservoir tank can be the bane of existence for a Cartier lighter owner. Unlike most butane lighters which have gas tanks integral to the lighter, Cartier utilizes a user removable tank. Cartier only warrants the tank for two years. I've also seen tanks that say 12 months. New Cartiers come with one spare tank. I've seen spare tanks come up on eBay from time to time, for $30 - $50. If not, picking up a beat-up Cartier on the cheap just to remove and use its tank is an idea. Cartier does not sell spare parts of any kind (other than flints), so if your lighter needs a new tank they will probably insist you get a complete maintenance service, which can cost up to $300.
Jul 16, 2009 | Cartier Tank Solo Watch
Submariner 16610 M Model has 40 seconds faster
I don't know if I can help you out, but I can tell you that even a low quality Daytona, or Submariner copy can be adjusted. My 1992 Daytona copy is at about 10 sec a month fast. I read a **** load about the movement, and did the adjustment myself. Any watch shop that tunes watches can do it.
I don't know what year your Submariner is, but today Rolex is using a new main spring (it is now blue). I would think a replacement spring would be the most you might need, but a good tune-up should do the trick. If it is real, I would think about sending it to Rolex for cleaning and a tune-up ($$$).
Jan 27, 2009 | Rolex Daytona 116520 Wrist Watch
Pocketwatch runs fast
Such a fast gaining usually is caused by dirty or magnetized hairspring, resulting in uneven coil amplitude (some of the coil rows are sticking together or touching each other). This causes the watch to run unbelievably fast.
To get the watch properly fixed you need to give to the watchmaker.
Alternetively; you can fix it yourself, but it will not last long.
For this you will need:
Case opener,
Dust blower (resin ball with nozzle),
Lighter fluid (ZIPPO),
Dropper (like one in eyedrops package).
Do as follows:
Open watch caseback,
Check for the fastest moving part in watch movement and you will see the hairspring fitted on it (pulsing outwards and inwards very fast).
Fill the VERY CLEAN dropper with lighter fluid.
Put ONE drop of lighter fluid on hairspring (DO NOT TOUCH IT),
Wait for a 10 seconds,
Dry out the lighter fluid with dust blower by vigorously squeezing it and pointing the nozzle on to hairspring from approx. 2-3 inches away.
Lay the watch on the table (dial down) and cover it with a clean, dustless cup. Leave for 15 minutes.
Fit the caseback on and enjoy your watch again.
Jan 26, 2009 | Geneve Watches
Watches Logo
24 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
