I had the same probelm:My phone started using a female to tell me if somebody called to sent a text message. Phone: LG Lotus LX600 Solution: Tools -> 6)Voice Control -> 5)Voice GuideSet Alert to OffSet Reader to Off I don't know how it got into this state, but turning off the Voice Guide Alert and Reader made it go away.
If it is a clean cut, and not all mangled up. You can get a male or female replacement plug at any hardware store to replace the cut off end. Hope this helps you.
wear and tear , most ipods over time end up with this problem specially if you use it a lot , and are very active . the headphone jack inside gets damaged , usually bent so that it does not make a good connection . if you don't want to spend the money to get it fixed , here is a easy fix that's fairly cheap . first link is ipod docking connector with male headphone out , and the next link is female to female coupler so that you can still use your headphones .
1. Check whether power is there 2. Check the power sockets receives the power supply 3. Check the Female socket on power chord is fix with male socket on monitor 4. Check the power chord is leak free.
It is most likely the female jack your adapter plugs into. Many laptops can have this port break if the laptop is put into a bag, etc with the power chord attached. Since it is attached to the main board itself, this is very hard to fix. Some vendors however will cover it under the manufacturer's warranty.
try going to radio shack and asking someone who works there to help find a AV female to AV input chord.
hook up the device that has a male AV out plug to the AV female plug and hhok it up to your DVD player
