Question about Cell Phones
What can be the problem in this phone Its not working though it is charged...
  • Shekhar Pandey
    Shekhar Pandey Apr 26, 2017
    Please reply fast
  • Mike Snyder Apr 26, 2017
    First of all you didn't say if you can see the screen.. so try to hold the volume up button and power button until you see it start this fixes the problem most the Time..
Battery on G-zone Commando Losing charge even though it shows it is charging
A charger can indicate it is working but if it is trying to charge a dead battery you will get the result you describe.
Mar 09, 2014 | Casio G-zone Commando
My Motorola V9 says invalid battery even though the phone works ok, though not sure if its charging up ok?
These are smart batteries. They have a circuit board that communicates with the phone. If the same battery worked fine before, then the circuit board in the battery is probably faulty. The battery should charge the same, but it may not report all the information back to the phone that it needs. If it becomes a problem with the battery then you should consider replacing it.
Jun 15, 2011 | Motorola Mobility MOTORAZR2 V9 Cellular...
My Xperia 10i is not getting charged though my charger is working properly. Once charger is pluged charge light indicated gets on but no any battery charging indication can be found on the screen. My I...
when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Jun 13, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My XPERIA X8 is charging properly with a Charger but it does not charge with a USB Cable 2.0 when i connect it with the PC, it shows orange light but it does'nt charge at all... it started happening after...
I have the X10 and it charges but very slowly.
Make sure that you DON'T mount your sd card when you connect your phone.
If you just leave it you should see your battery icon scrolling up through the colours as though it is charging.
That means it is charging. As I say though...It's very slow!.
Try unplugging from the computer and from phone then plug them in again. Sometimes this works for me. :)
Updating shouldn't have a detrimental affect on hardware so I shouldn't think the problem is terminal.
Mar 01, 2011 | Sony Ericsson Xperia X8 Charging USB 2.0...
Phone not charge
u need to check if there is a charging pin in the working ?
Oct 22, 2009 | Cell Phones
K660i not charging the battery though indicator says charging
the the charger terminal, but the first thing is try to replace another battery
Aug 07, 2009 | Sony Ericsson K660i Cellular Phone
Can't access internet on my sony ericsson Z750a
Yes, perhaps that an add on and you might have to ring your provider and get the phone enabled. I disabled mine because I kept hitting the browser button and got charged everytime it happened even though I didn't access the internet. Anyway do this I am sure it will work, watch charges though, make sure you are covered, or aware of what it will cost.
Apr 25, 2009 | Sony Ericsson Z750a Cellular Phone
Unable to charge
Same problem here but phone is 14 mo old. Just stopped charging even though it says it is. Got new battery, same thing. Charged battery in different phone and was fine. swapped and it works. so... phone is bad somehow.
Apr 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Mobile phone
check the port of u r h/s , problem is in your mobile port, thats y u are not able to charge or syncronization
Sep 24, 2007 | Sony Ericsson K750i Cellular Phone
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
