Question about Sewing Machines
What stitch setting do I use for a satin stitch?
  • 64 Answers
Depending upon the machine, whether it is electronic or a manual setting, most settings for satin stitch are shown as a zigzag with Length being the primary changeable setting.
If you want a 1/4 inch stitch, your width should be set for 6mm. on an electronic machine with the Length at or about 0.3 mm.
On a manual machine you will have to adjust the length until you get the effect that you want.
In either case use a scrap of fabric to test your stitches and then record the settings that you like best.
Posted on Apr 26, 2017
Need to do a satin stitch on Bernini 1630
Just set it for a short stitch length and a wide zig-zag. Test it and keep adjusting the stitch length so the thread will not overlap from stitch to stitch but also that the stitches are close enough so no fabric shows between the stitches.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
How to Sew Satin Stitch
Nov 28, 2017 | Sewing Machines
What is the setting for satin stiches
Depends on your machine and the thread you are using. A satin stitch is a zig-zag with the stitch length set so the fabric is not visible between the stitches but the stitches do not overlap.
Satin stitch Wikipedia
Jun 26, 2017 | Sewing Machines
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Feb 19, 2017 | Sewing Machines
I have a Bernina 145 S activa and I can't get my satin stitch to work , it brings the bobbin thread to the top , what can I do ?
Do you use stabilizer when you are satin stitching? I had a teacher who also hooped the fabric with a spring-loaded embroidery hoop (turned upside-down under the presser foot so the fabric is flat against the needle plate) that would keep the fabric taut.
It is not uncommon for bobbin thread to rise to the top when doing embroidery, satin stitch, etc., especially if you are using lighter-weight thread than usual. You would normally loosen the upper tension so the upper thread will sink into the fabric. However, if loosened upper tension is not doing enough, you may need to adjust bobbin tension when doing embroidery, applique... You might try tightening the bobbin tension just a smidgen to get the bobbin thread to stay below the fabric. Be sure to mark the bobbin case before making any adjustments so you can return it to the original setting when finished with the satin stitch. (If you do a lot of satin stitch or applique, etc., you may want to invest in a separate bobbin case that is set up only for doing that kind of work--saves having to alter the bobbin tension frequently.)
Mar 16, 2016 | Bernina Sewing Machines
What can I do to widen my satin stitch when it is to narrow for the applique
Unless you have and know how to use digitizing software, will you be able to add width to the satin stitches when doing applique. You need to cut the applique fabric larger than the cut-out-line so the applique fabric will held down properly. Some Commercial or higher end home embroidery machines can re-interpret the embroidery design and widen the satin stitches in a design without software. 6f3dbcfe-19c3-4021-b143-de10c9a89868.jpg
Jul 14, 2014 | Brother PE770 Computerized Sewing Machine
Bernina buttonhole 730
Use your ruler and measure your button. Then transfer those measurements to your garment.
Use chalk to mark the center cut line of your button hole. Mark the end or stop point of the button hole per the measurement.
Practice on a scrap of the same fabric before you begin on your garment.
Set your machine the satin stitch zig zag at a fairly narrow width.
Begin satin on one side of the center line of the mark. Slowly stitch down that side until you get to the end. STOP. Widen your satin stitch to the max. sew about 1/8" and stop with the needle down on the opposite side to your first line of stitching. Turn the fabric, narrow the stitch to match original satin stitch. Sew slowly down the other side of the center mark. STOP, lengthen the stitch, sew 1/8" then do a couple back stitches.
That's one way. Another older way is to sew 2 or tree straight stitch lines around the center line. Remove then use a hand rendered button hole stitch after you cut the hole.
Oct 27, 2013 | Husqvarna Sewing Machines
On satin stitch setting, machine is only stitching left side
if the fabric is thin then it needs something with it to make it strong enough to handle the stitch,,I suggest trying a washable stabilizer or interfacing & see if that will help the stitch to be normal
Mar 06, 2012 | Euro-Pro Shark 60 - 384
I need to satin stitch around the edge of a project
Try using the zig-zag setting, but adjust the stitch length to .3 or .4 (very small).
good luck!
Dec 08, 2008 | Baby Lock Esante
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
