Question about Refrigerators
Water is forming on the floor. Appears the water is pooling under the crisper drawer, then seeps through the seal. GE TBX 18CI. Any ideas?
    Scholar:
  • 117 Answers
You should not have any water at all forming inside the frig compartment unless you have a water dispenser on the frig. The water resevoir is located in the frig compartment at the bottom behind crisper. There may be a small leak or loose water connection on it. Hope this helps.
Posted on Jul 25, 2009
My lg express cool gr482sf has water forming under the crisper. so far both freezer and refrigerator are working well
water condensation? Usuallya s a result of bad door seals allowing air into the fridge and then the moister condensates and becomes water at the bottom of fridge or drawers
Feb 16, 2015 | LG Refrigerators
I have a 2002 GE Arctica (PSS25NGMDWW) side-by-side refrigerator and recently has started pooling up water underneath the crisper drawer.
check the drain on the refrigerator side also you may have to disconnect to open the panel and clear with hot water or a heat gun.
Dec 19, 2014 | GE Refrigerators
Water in bottom left crisper drawer and under drawer
I'm sorry to say that it sound as though your door gasket may no longer be sealing correctly.
For me, it's simply a task of getting a replacement gasket for that make and model.
To remove the old one you would, simply, peel the inside of the gasket toward the outside of the edge of the door revealing the mounting screws. Remove these screws all the way around and replace with the new one in the same fashion...
The reason that I recommend this is that humid air outside of the refrigerator can seep past a worn gasket and condense on the inside surfaces making its way to the bottom and into those drawers.
Feb 16, 2014 | Whirlpool Refrigerators
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
Refrigerator leaking water
This sounds like the water line from the icemaker and the cool water reservior inside the refridgerator side. The line is a rigid plastic hose and could be a leak at one point that is small enough to allow water to run along the line. Also sounds like you have a humidity problem. Check the door seals and wipe them off and apply a thin coat of die-electric grease to the seal. this will help keep it pliable and soft.
The water in the bottom leaks into a trough that is made into the fridge. This usaully evaporates, This is for the auto-defrost. It keeps the water from getting on the floor.
Check to see if the outer door gets hot at the edges. If not, It may not be auto-defrosting.
I would first check the water line first as this seems to be a more serious issue right now. The line is probably loose at one of the connections between the ice maker and water reservior.
Jun 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water pooling under my express thaw bin in bottom of refrigerator
no connection between lower drawer and water dispenser, however there is a water tank behind the crisper's storing water for the dispenser, its possible that there is a hole in the tank or a connection is leaking there and dripping water. remove all 3 crisper's and give a look at it. try getting water from dispenser while your checking (Might only leak when water dispenses
Mar 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
438 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
