Question about Universal Televison & Video
I can turn my TV on and off using a universal remote but it will not change channels or turn up-and-down and I cannot bring up the menu need help ASAP
  • 275 Answers
SOURCE: Lost functionality w/ Universal Remote
Now, it depends upoon the Universal Remote u purchased. If your remote has the neccesary buttons - AV/TV switching,Front - Rear Input Switching, Menu, etc, it should work! Since there are multiple codes for every brand, keep feeding the various codes one by one, and checking if the neccesary functions operate. If, finally, you are unsuccesful, then, folow techman's advice. Best of Luck.
Posted on Jul 22, 2006
ice man
  • 68 Answers
SOURCE: after programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Posted on Mar 25, 2007
bkvinr
  • 76 Answers
SOURCE: can't access channels 3 and 4
Open main menu and select manual program. In this option check skip on/off option is there. Otherwise select autoprogram the channels are automatically stored, after completing autoprogram TV displays program edit option. In that you can choose your needs.
Posted on Sep 09, 2007
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
SOURCE: the universal remote does not bring up the menu
If You have a cable box. Program your Tv to it and use the set up or menu button yo program it.
Posted on Aug 06, 2008
I have a Philips tv model 42FD9954/69c but it doesn't have a remote so I cant turn it on how do you get it to work with a universal remote ?!
Most TVs have controls on the side of the TV to operate power, volume and channels, if the power button puts it to standby then use the Chanel up or down to turn it on! Depending on the universal remote being used just select the code relevant to the make of TV you are connecting to!
Nov 01, 2014 | Televison & Video
How to get universal remote to turn the tv to game mode
I don't know if this can be done with a universal remote, but if you can let me know which brand and model of universal remote you are using, I will check if it is possible. If your universal remote has an "AV", "SOURCE" or "INPUT" button, try these but make sure the game system is switched on so you are able to see if/when you have changed to the correct mode.
If you don't have the original Symphonic remote, you should be able to switch the TV to game mode using the buttons on the front of the TV as follows:
1. Switch the game system on
2. Press the "MENU" button on the front of the TV
3. Highlight "PICTURE" using the CHANNEL UP/DOWN buttons
4. Press the VOLUME UP button once to enter the PICTURE menu
5. Highlight "GAME MODE" using the CHANNEL UP/DOWN buttons
6. Use the VOLUME UP/DOWN buttons to set "GAME MODE" to "ON"
7. Press "MENU" to exit the menu and play games.
The menu should automatically close anyway if you don't press any buttons for about 15 seconds.
When you have finished playing your game, repeat the above steps to set "GAME MODE" back to "OFF" and return to watching TV.
Hope this helps. Please post back for further assistance if needed.
Regards,
BElectric.
Dec 23, 2010 | Symphonic ST419E TV
I have a mitsubishi tv model cs27200 and I dont have a remote. I got a universal remote but it wont bring up the menu. I need to program the channels for cable. I only get local channels without bringing...
You would need to look up how to program that remote to your specific tv. I would look up the owners manual if you dont have it for the remote...and follow the instructions for it. However, you will have to directly use the tv to program it to the cable. The universal remote will only change the channels and volume for you. Use your menu button to bring it up, make sure its set to cable and not antenna, and use your channel + and - to navigate through the menu and vol + to select your option
Nov 20, 2010 | Televison & Video
I need to reprogram my rcr317w remote contact with manual
Turn the tv on. Hook up your components, turn them on, go in to tv menu and auto program the stations. It will see that there is a signal on channel 3 and lock it in for you.
Jun 30, 2009 | Universal Remote Control DIRECTV Universal...
I can't program the remote to work on the tv.
i need directions on setting up my remote for my sony tv and what the code is
Apr 07, 2009 | RCA Universal Remote Control
Code for tv durabranb 1301
I own a One-for-All universal remote, and my booklet says the setup code for a Durabrand TV (without a built-in DVD or VCR) is one of the following numbers: 0171, 0178, 0180, 0463, 1034. I can not guarantee that these numbers will work with your remote, but it is worth a try.
Jul 09, 2008 | Durabrand DU1301 TV
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
Universal remote(s) won't work
Use the buttons on front of your (tv) channel up & down allows you to scoll thur menu vol- vol+ allows you to adjust settings.Need anymore help let me know. ThankYou for using FixYa. Have a Nice Day.
Aug 26, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
The universal remote does not bring up the menu so I can program all the cable channels in it. I don't know what to do. It is only receiving non cable channels. Help me so I don't have to keep watching...
alot of universal remotes dont let you program your tv with them due to how much more mem they would need. you have to use your actual tv remote or do it manually with the tv. sorry
Jul 29, 2007 | Sharp 13VT-R100 13 in. TV/VCR Combo
Televison & Video Logo
21 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
