My Optima TH1020 color is off. The red is orange and faces look horrible. I had tried messing with the settings but nothing works. Any help would be awesome!
SOURCE: color on projection tv 9P6040-C104
HOW CAN I REPLACE THE FLUID IN THE CRT'S WHERE DO I GET THIS FLUID
Posted on Feb 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: Color problems
Your color wheel is bad. Thats the only thig that controls color on the DLP projections. You will need to replace it But I would check the connections on it first to make sure the connections are secure. Let me know if you require more assistance.
Posted on Feb 26, 2008
SOURCE: Color Problem
Ok try turning the tv of for (1)Hour by the power point and back on After and Hour Is UP. that way it will reset picture -
Make sure you un plugged it by the power point for the full 1hr
also make sure there is no speakers or anything magnetic within 90cm's of the tv this can also cause
the picture to have strange colors in the screen - if that happens simple Repeat the above
Posted on Sep 22, 2008
  • 267 Answers
SOURCE: Olevia 42" HD LCD problems with the color
YOU PROBABLY HAVE A PROBLEM WITH THE MAIN TOTAL ASSY WHICH PROCESSES THE CHROMA FOR THE SET. THE BOARD WILL NEED TO BE REPLACED.
Posted on Feb 03, 2009
SOURCE: i have a samsung lcd about 1 year old. im having
im not an expert but it sounds like a main board problem. check out my work place web site during bus. hours we are a tv parts store with online help or call and talk with someone. www.shopjimmy.com we can find out if we have what you need and walk you through how to go about changing any boards that might need to be replaced.
Posted on Apr 07, 2009
We have a JVC LT-32JM30 and recently for no reason at all, the picture color has messed up, we have tried resetting and adjusting the tinit, etc but nothing works. Everything is a varying shade of green or...
an internal degaussing coil circuit is already installed in the unit to neutralized color pattern...a loose solder connection may have caused this because as it operates temperature increases between the thermistor..
Jul 15, 2011 | JVC AV-27530 27" TV
Something has happened to the color on my tv. it's lost the reds in the picture. face color is good. pinks, blues and greens are ok. i've unplugged and re-started. how do you go back to default...
Look for color temperature settings under the menu and video settings. If there is an overall factory reset or restore to factory settings, try that as a last resort.
Mar 06, 2018 | Tatung P42BSKH Television
Dear Sir, Hope you are doing well. I bought KIA optima 2007, from USA, the tail sign (tail direction light) is red color, and it provided with Orange color, but it inactive from the factory. So,...
WELL REAR TAIL LIGHT SIGNAL BULB SHOULD BE CLEAR BULB FRONT TURN SIGNAL BULB SHOULD BE ORANGE COLOR.TAKE BULB TO ANY AUTO PARTS STORES THEY WILL GIVE YOU THE CORRECT BULB.
Nov 29, 2010 | 2007 Kia Optima
With my d90 reds come out as orange how do i stop
My guess is that it's not the camera but it's your monitor calibration. Reds (especially brightly lit reds) are the most difficult to render on a monitor. I would try changing the Vivid color option on the camera as well as saturation and even the color space options to see if you get any variation. Also, consider looking into a monitor calibration utility. If you have a color printer, you can print an image that looks orange on your monitor to see if it prints the same way.
Dec 24, 2009 | Nikon D90 Digital Camera with 18-200mm...
Background color is orange instead of blue, color is messed up
Usually this problem is a simple one to find out.Are you wires working correctly.If they are not,open up the box and,if you are a professional so I dont get sued for some accident,try to splice the wires back.If your not a pro take it to the retailer and have it fixed.If it is not the wires,I would check your color settings option in the DVD options menu.Check your red blue green balance and make sure they are correct.
Mar 24, 2009 | Philips DVP5990 DVD Player
Jan 31, 2009 | Olevia LT42HVi 42 in. LCD Television
Color problems
Feb 26, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Color on projection tv 9P6040-C104
The cooling fluid in the CRT's need to be replaced. This is a common issue with NAP projection TV's. The old fluid needs to be drained then the CRT faces cleaned then refill with new fluid.
Jan 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
