Question about Samsung Televison & Video
My Samsung Plasma TV has vertical lines on it. Is there a way to test the unit myself without resorting to taking it in to a repair shop??Any ideas would be greatly appreciated!!
    Scholar:
  • 70 Answers
Means the glue or rubber padding on the gold static conductors are coming unstuck at the top of the screen just under the top of the plastic frame or has dirt...maybe this video is helpful, also happens to all Plasma and LCD and computer Monitors, it's definitely not a Motherboard issue it is a simple annoying fix but a real pain to get too if you have the patience.
LCD TV Repair Secrets Vertical Lines on the Screen
Posted on Apr 26, 2017
SOURCE: MS-1036 doesnt sense power cord attached
You hit exactly on the head with don't move the unit when plugged in - there are many people with the MS-1036 having this problem if you search the web. MSI does cover the bare-bone itself, however this falls into that damaged not defective area. Many shops would replace the entire board, making it costly as looks you had done once already. Good idea is to look to Asus 17" bare-bone and move your items over, much better made. Citrus Micro - see you worked with them, so have I, always had good luck with them, they make great contact and sometimes too honest, prices are great to - like any etail store with returns, manufacturer warranty tells most etail stores how they are to handle things. Could be why you see them getting rid of selling MSI products? Looks like you found the best idea, take to walk in repair shop - hard to beat that or again, buy new bare-bone.
Posted on Sep 07, 2007
  • 6 Answers
SOURCE: THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Posted on Feb 15, 2008
SOURCE: Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Posted on Nov 21, 2008
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Posted on Aug 19, 2009
SOURCE: plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Posted on Jan 27, 2012
Samsung Smart T.V. repair, Is having vertical multiple lines and not imagen what I cand do?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 30, 2016 | Samsung Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
How do you fix an LG 50 in Plasma TV with vertical lines?
the vertical stabilizer module circuit burned out.
without schematics ohms meter, oscilloscope, soldering tools,
proper grounds, layout configuration of the circuits configuration, signal generator, you have big project, take it to a professional or repair shop.
Sep 18, 2015 | LG Televison & Video
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
Started out vertical lines and smear on the left side of the screen but will disappear after 10mins but got longer and longer. Now 2/3 of the screen is permanently dark I had Samsung TV repair guy check...
If you wish to get some details; visit the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 19, 2017 | Samsung LN52A850 52 in. LCD HDTV
Colored "snow" vertical line an inch thick on Samsung plasma
That is the sustain and buffer boards. Try to find a repair shop to repair on the component/board level because the cost of new boards out weighs the replacement cost.
Best Regards,
Beach TV Repair
Jul 04, 2010 | Samsung PN50A450 50 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Televison & Video Logo
120 people viewed this question
Jerry Greenberg
Jerry Greenberg
