If the projection light is on and there is no information , is there a fix for this ?
The unit will not turn on. A red light blinds and that it. No picture and no sound
I have the same problem on the same tv. If you have fixed it by now please inform me how, I would really appreciate it. And vice versa if I get mine fixed.
Aug 08, 2011 | Toshiba 65H84 65" Rear Projection HDTV
WS-65513 Blinking power light problem......
Mike send me an email to my private email slinteriors@yahoo.com and I will send the detailed instructions to you with pictures.
May 12, 2008 | Mitsubishi WS-65513 65" Rear Projection...
I have 2004 GE 52' Projection TV and it won't turn on. All it does is the power button lights up three times and it makes a flick sound and it never shows turns on or shows anything. How can I fix this?
I have the same issue! Did you ever find anything out on yours? Any information would be great! I would hate to throw the TV away because when it's on it works great!
Thanks
Alexis
Dec 21, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Blue Screen
One of two things happened. The light engine died, or if that unit uses a single lamp, it died. Most Mitsubishi's used three lamps leading to the light engine. I am trying to fix my neighbors now and was lucky enough to find an engine for under $300. Dealers will charge between $800 and $1500 to fix this. Confirmation can only be done by a tech inspection. If the power button blinks a specific color or pattern repost with that information.
Jun 30, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitzubishi projection tv power shut down and won't power back up. green light comes on for a second then it shuts down immeditately
MOST Mitsubishi sets have a self check feature:
When power light goes off: On the front of the set press and hold MENU and INPUT (device) BOTH FOR 5 SECONDS OR LONGER AND RELEASE.
POWER light should blink a two digit code: for example:
2 blinks, a pause and 2 blinks----it will repeat the error code several times.
2,2 is the most common and the least expensive to fix.
LET ME KNOW EXACT MODEL NUMBER and the blink code and I will tell you what it means and if 2,2 how to fix it.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Televison & Video
10 year old hitachi rear projection starting to make black look green, any way to fix
Yes it is repairable you are going to need a new gun for it they cost arounf $150 each for this model new and can be put in for around $20 per hour min 1 hour labor. If this information helps you out please rate it as Fixya because there is no quick fix to this situation and I am relaying good information.
Apr 25, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Turn tv on, sound comes on but no picture, power light blinks,
The clear bulb located back left side needed to be replaced. Too much heat causes the bulb to burn out. Simple fix. One screw to open door to bulb compartment. Two screws to remove bulb assembly. Thank goodness for extended service warranty which paid for it. This is the second one in three years. At the price of $200 for bulb and $100 for trip and labor, this is not an inexpensive fix. Anyone purchasing a projection tv should get an extended warranty.
Apr 08, 2009 | RCA P61940 61" Rear Projection Television
Mits. TV Green light blinking issue.
Just click below for information related to your problem;
http://www.fixya.com/support/t1012464-fixed_blinking_light_but_still_no
Hope it may help you;
Regards;
VOTIT
Jan 20, 2009 | Mitsubishi WS-65513 65" Rear Projection...
T.v. power led will only flash...
i have the same problem as you,also my audio jacks no longer work.sending for repairs i will contact you as soon as my tv comes back.with the information whats wrong..and if it can be fixed. I am a fellow Toshiba guy who goes by the handle Moonbasealpha...
Feb 29, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
