Question about The Audio Players & Recorders
Grinding s350dl shuts off 1 min. after listening only on the sw not on am or fm only sw shuts off. Why ?
4 Suggested Answers
adib
  • 450 Answers
SOURCE: iPaq 4355
f you go to http://www.radio-locator.com/ there are a large number of internet radio stations that you can thru the ipaq.
Posted on Sep 11, 2005
  • 6 Answers
SOURCE: Grundig S350DL shuts itself off
The default mode for this radio is in "sleep-timer." You can adjust the time it stays on or you can hold the On/Off button down for a few seconds as you turn it on. (You'll notice the "bed" icon no longer appears.)
Posted on Jan 05, 2009
kb8dns
  • 494 Answers
SOURCE: The sound on AM channel is very poor while that on FM is excellent.What is the cause of this problem ?
Usual problem can be traced back to faulty electrolytic capacitors, solution is to replace all capacitors and make sure any leakage is cleaned up with needed repairs. Contact me if you need help.... poikaa(at)yahoo(dot)com
Posted on Feb 06, 2012
How do I change my cd clock radio to AM
probably doesnt have AM option. You have high quality CD sound and high quality FM sound, they don't let you have bad quality AM. Having said that it does.
LISTENING TO THE AM/FM RADIO 1.
Press the ALM OFF/SOURCE button to select the FM or AM mode.
2.
Press the
/MIN button or
/HR button step by step to tune to the desired radio stations.
3.
Press and hold the
/MIN button or
next radio station in the direction of the search. The search operation simply finds stations with
strong signals. Stations with weak reception can only be tuned in manually
THIS MANUAL IS FOR THE 201
Onn ONB14AV201 Product Manual Product Features View
Jul 09, 2017 | Audio Players & Recorders
Radio shuts down
Does it shut down with the AC adaptor pluged in and no batteries?
Jan 10, 2008 | Grundig YB 300PE AM/FM/SW Radio
Dec 22, 2011 | Sony ICF-SW77 AM/FM/SW Radio
I have a Grundig radio S350DL and I cannot switch off the sleep function and therefore the radio automatically switches off after 30 mins. or so . Can you advise? Les. Akers
The Power and Sleep Functions share the same button. If you press the Power/Sleep button repeatedly you see numbers displayed 90, 75 60, ... 01. These are the duration of the sleep functions. If you stop at 60 the radio will work for 60 minutes then turns itself off. This must be a battery saving feature so that a radio will not be on for ever. Suppose the radio has been on for a while (long or short) and you want to turn it off without waiting for the sleep timer. Just press the Power/Sleep button.
Aug 10, 2011 | Grundig S350DLB FM Radio
Hiss when listening to FM Stereo on headphones?
Usual problem is FM alignment also may point to a capacitor problem. I have repaired many of this nature. Contact me .... poikaa(at)yahoo(dot)com
Mar 01, 2011 | Sony ICF-SW77 AM/FM/SW Radio
Sony icf-sw77 - listening to FM if station feq is 102.0 it's distorted so have to tune to 102.05 - what's wrong here? It's the same for all FM stations AM seems fine...
Common problem and will need realignment and / or capacitor replacement. Usually on a few are bad but I recommend all to be replaced. Contact me .... poikaa(at)yahoo(dot)com
Dec 21, 2010 | Sony ICF-SW77 AM/FM/SW Radio
My 4 year old YB P 2000 suddenly quit broadcasting AM. I took the radio apart and cleaned everything. Now only some FM stations and no SW reception. Can you help?
Look at the front case and locate reset hole. Insert cocktale stick or similar and listen for slight click. Insert new batteries, ensuring correct polarity and that there has been no leakage from old batteries on terminals. If leakage ie green/ uneven appearance, try to scrape clean with suitable implement when disconnected from mains only.
Feb 10, 2010 | Grundig Yacht Boy P2000 AM/FM/SW Radio
We have a Grundig S350DL radio that was my father's. There is no manual. FM works great. Can't get AM. Radio turns off on its own!! Any suggestions?
The problem you are having may be due to some configuration settings (such as a timer). Not dtecting the AM signal, may be due to interference from power lines. To improve AM reception (if there is something to improve) one should rotate the radio to orient the internal ferrite antenna. Using the radio close to a window can improve reception.
To enable you to diagnose the problems that may be due to some configuration setting I give you the link to the radio's manual.
Hope it helps.
Nov 08, 2009 | Grundig S350 AM/FM/SW Radio
Grundig S350DL needs a am aerial to bring in the
1. run 18 gauge wire (buy in auto parts shelf), after stripping plastic (about 1/2 inch) away from wire inside. Clip where RED clip is, on back of radio. Need about 6 to 10 feet. Run wire in upwards direction from radio. At other end of wire, strip enough to make small loop back onto itself. (terminates the wire.) Run another length of same wire from BLACK clip on back of radio, strung along floor of room - 6 feet, maybe. Yes, hide it if it does not please somebody's eyes. Now, you have an AM external antenna.
2. Go to E-Bay, "slinkyantennas". They have a very good-looking, and performs for DX'ing antenna. Use same wire from RED clip, stripped, for alligator clip from 'slinky' shop's antenna to grab hold.
--With s350dl (NPR version-before major t-storm did kaputs, learned good lesson ... always use batteries, not A/C), and slinky pvc-style antenna with ground wire, was able from Central Louisiana, to pick up KOA from Denver!
Feb 28, 2009 | Grundig S350 AM/FM/SW Radio
Nov 30, 2008 | Audio Players & Recorders
23 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
