Question about Cell Phones
When call button is press then mobile restart
How to restart mobile
Press and hold the power button of your mobile for 3-4 seconds and release. Slide down if it asks you for shutdown
Let it completely shutdown and after that press and hold the power button for 2-3 seconds and release then it will be restarted
Nov 20, 2015 | Cell Phones
The mobile stop at sony logo and restart again i can`t open it
power off.pulling battery or any way.
press PDA button VOL+and power button together.
or try VOL+and power together hold the keys untill you feel vibration and let the brand name comes up and let all buttons free.
the it will boot recovery mode.then select factory data reset by pressing VOL+ and _
select by the power button.
after that it reboot phone.
Aug 20, 2014 | Sony Ericsson Xperia Arc S
This is what happens when I turn on my HTC phone
First : you need to remove the battery from your mobile then re install it.Then you need to press the home button and keep pressing ,then the camera button and keep pressing too then the power button ,after that the phone will reboot ,now just press the back button then the send button, the phone will restart and work correctly.
Feb 27, 2013 | Cell Phones
I cant restart my LG MyTouch, E739 smartphone.
There is a problem in your system I would recommend you to check your manual and if you do not find any thing to fix it it probably needs to be sent to the manufateruer
Apr 19, 2012 | LG myTouch T 4G MobiPhone - Black T-Mobile...
Mobile softwear virus attack. mobile virus scaning is ok but no work. now mobile 5 min. after automatically restart. and mobile IME code is fault
This is a guide how to reset your phone to factory setting eliminating all problems/viruses.
C.O.D.E 1: --->>*#7370#
C.O.D.E 2: --->>
STEP: 1. Switch off your Nokia Mobile,
STEP: 2. Press-> Call button, press-> 3, press-> *,
STEP: 3. Now Switch on your Mobile.
Mar 06, 2011 | Nokia 7210
I forgot lock code of nokia n73 mobile
i am not sure if this will work but try it:
turn on the phone and you have to press down these three buttons at the same time
Green Send button + 3 + *
Keep these buttons pressed and switch the phone on. Wait till you see the message 'formatting...' and then stop pressing the buttons.
May 20, 2010 | Nokia N73 Cellular Phone
How to reset nokia n95 8gb
Soft reset code *#7370#
Hard reset code *#7780#
If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
+ Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
+ While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Regards, WAQAR.
Nov 28, 2009 | Nokia N95 Cellular Phone
My nokia n70 handset restarts automatically ..also it has the hanging problem ,i have to remove the battery and then insert by that time also it starts without pressing the start switch .while it is kept...
I am sure that you mobile is effected with virus, I request you to format the phone.
Here is the steps to format the Nokia N 70 mobile.
Before formating the phone please take the backup of the contacts and messages.
Turn off the mobile.
Press and hold call button + star button + number 3 and turn on the mobile and wait until you see time settings.
This should fix the issue.
Oct 15, 2009 | Nokia N70 Cellular Phone
Mobile phone restarting
Its a software problem,to fix it by reprogramming with a latest version.But you can tray to formatt first,in some case it works.Make sure your battery full charge,remove the battery than insert back.To format you must press and hold * button,number 3 button, Send (call) button than press and hold power on button,do not release your finger till FORMATTING appear on your screen,tray again if not works. Good luck.
Jun 30, 2009 | Nokia 3660
Gud evening sir im ravi my mobil model no is nokia 3110 c i have one problam my musiplayer is not opening how will solve that prolam
1.Format your memory card
2.Make shortcut on your mobile so u can access very fast to your media player
2.2. In SETTINGS/MY SHORTSUTS/NAVIGATION KEY make it so that standby key is 2nd
2.3. Get back to main screen and press DOWN key, options, select, select media player, and save, in organise shortcuts make it 1st and save your progress
3.Upload up to 5 songs
4. Update your media player, mobile will restart him self! BUT!!!...
5. In order to stop restarting u have 3 sec to start updating music library again
6. If u done all at step 2, u need to press fast one time down, central button, left blue line, down, central, up, and central (Need to be pressed in 3 seconds)
7. If u success in this 6th step u hawe solwed problem!
8. Next step is to upload next 5 songs and repeat steps 4-6
(9.) If you cant press so fast buttons to restart uploading I suggest to create a folder named "Amp3" so he can be first when u access to your memoru card so you could
erase him fast to stop restarting, instead formating whole card (In SETTINGS/MY SHORTSUTS/LEFT SELECTION KEY(Make it Gallery, so you can access fast to memory card to delete folder "Amp3"))
(10.)Buttons to erase "Amp3 folder" - While in main screen press : Left blue line, center, left blue line, down, center, center (Need to be pressed in 3 seconds)
(11.)You hawe stopped restarting and kept pics, and images on memory card
Dec 04, 2008 | Nokia 3110 Cellular Phone
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
