Question about Pentair Pool & Spa
I have a pentair easy touch and the waterfall is turning on will all programs. Have reset all schedules and still turns on . can tfigure out where it is reading to turn on waterfall
  • 2 more comments
  • amy miller
    amy miller Apr 27, 2017
    Steve, do you know where the toggle switch might be located? Is it on the main panel?
  • Steve Slater Apr 27, 2017
    On the valve itself. For these automated systems they add a motorized actuator to the top of a standard manual valve. Plumbers will usually place the valve so the handle is on top or easy to reach but the toggle is on the underside of the motor portion of the valve. It could be on the side dependant on the brand but usually the bottom. I would bet this valve is in close proximity to the pool equipment and main panel. The actuator will have a wire connecting to main panel and be located after the heater in plumbing scenario.
  • amy miller
    amy miller Apr 28, 2017
    Thank you Steve, located the toggle and I believe it's bad. Have changed the position to all 3 settings and the waterfall still comes on in all 3 positions.
  • Steve Slater Apr 29, 2017
    Does the actuator move? If so I would say something definately broke inside the valve. If not there is more troubleshooting to be done before replacing the actuator.
    In the main panel the wire from the actator is attached to a relay, this relay is responsible for sending power to the valve when needed. The relay gets power from the breakers in the panel, make sure all the breakers are on and not tripped. If thats not the problem you can turn power off then relocate the actuator to another relay. Note the different relay will be controlled by a different remote label no longer "waterfall" probably an un-named "aux" function.
    New Friend:
  • 66 Answers
It may be more of a mechanical problem than programing. There is typically a switch on the motorized valve itself. It can sometimes be hard to see or find. The switch is a three position switch. In the center is for remote use while switching it up or down will allow you to bypass the remote to open or close the valve. My guess is it could possibly in the open position so no matter what you tell it to do in the programming it is always open.
Posted on Apr 27, 2017
How to sync easy touch remote to outside
remote should sync as soon as you turn it on and it connects the programs are stored on control box
Sep 01, 2014 | Pentair Easy Touch Indoor Control Panel...
Can you hook up a jandy 4-button spaside remote to the pentair easytouch controller?
I've installed dozens of Pentair ez-touches. Call Pentair and ask them. I don't think you can, but I could be wrong. Plus, in my opinion, Jandy isn't a very good brand anyway. Just get the one that is supposed to go with the ez touch. It's easy to run and program and you already know it's going to work because it was made for the ez touch system. You'll save yourself a lot of headaches by not trying to save a couple of bucks.
Feb 28, 2014 | Pentair Easy Touch Indoor Control Panel...
Spa waterfall isn't flowing
If you turn the valve to operate the waterfall feature on your spa and no water is coming out of it, my best guess would be the valve is broken and not turning to allow the water to go to the waterfall.
Pull the top of the valve off and look inside for a broken part.
US Parts Center
Feb 11, 2013 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair eAsy touch remote can't find wireless address
turn off then back on if still cant find have to put in manually
Jun 18, 2012 | Pentair Easy Touch Indoor Control Panel...
My Pentair easy touch control panel quit working. I power it down with the breaker power it back up and the screen comes on for a bit and I can even turn the filter on but then the screen goes blank and...
I would call the Pentair technical support at 800-693-0971 number and they should be able help determine what to do next.
Pease let me know how this works out. Thank you.
Aug 31, 2011 | Pentair Easy Touch Indoor Control Panel...
Pentair Easy Touch remote lost sync with the outside unit. Have tried resyncing a dozen times, per the manual, tried hitting the reset button and then resyncing...nothing worked. I removed the cover on...
Try turning the whole system power off at the main house panel, wait a minute, turn power back on, then go to the pool panel and reset communication as per manual instructions. This worked for me.
Sep 25, 2010 | Pentair Easy Touch Indoor Control Panel...
I have an Easy Touch 4 2 yrs old. The remote
If you have replaced the batteries then it is a bad remote. Most builders who install Pentair equipment give you a 3 year warranty and will replace it for free...I do Pentair Warranty in N Cal
Aug 29, 2009 | Pentair Pen520548 - Easytouch Indoor...
Pool & Spa Logo
107 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
