Question about The Computers & Internet
What does the circulatory system do? - The Computers & Internet
  • The Master
  • 4,296 Answers
The human circulatory system carries blood to and from the heart all around the body delivering oxygen and nutrients to all parts and carrying away excess fluids and byproducts and delivering them to the liver and kidneys for removal.
Posted on Apr 26, 2017
Garlic is it ok for the heart
I am not an expert on diet or herbal medicine but I frequently hear garlic is very good for the blood and circulatory system and I guess what is good for the blood can't be bad for the heart - whether you eat it raw, cooked or prefer to take a couple of garlic pearls daily.
Oct 17, 2016 | Home
What about green tea?
Green tea is the healthiest beverage. I know it is quite not good in taste but it has many benefits from weight loss to cure skin problems. Some good things about green tea are as follows:
helps in weight loss
good in heart disease
prevent cancer
source of antioxidants
cures skin problems
controls cholesterol
lowers blood pressure
cures tooth decay
anti viral and anti bacterial
helps in depression.
Jul 04, 2014 | Kitchen Appliances - Others
Engineoverheats but still blows cold air
Your statement in it-selves solve the problem.
Your vehicle cooling system and air-conditioner system work independently.
Your vehicle cooling system is driven by the v-belt that turns the water-pump and circulates the coolant within the engine through the radiator and back into the engine and flow is controlled by a thermostat.
Your vehicle air-conditioning system operates from a v-belt that drives an air-conditioning pump which circulates coolant through a sealed system and generates cold air completely independently from the engine cooling system.
It seems that you need to repair the engine cooling system which has a fault and this fault could be
a) combustion seeping into cooling system (blown gasket),
b) cooling fan not operating (this fan engages at specific engine temperatures and suck cold air through the radiator in order to cool the engine coolant as it passes through radiator veins),
c) faulty cooling thermostat (thermostats work mechanically and through temperature expands and opens the water circulatory channel / opening, and in cold weather restricts this opening in order for coolant to allow engine to reach operating temperature and then allows the coolant to circulate freely),
d) engine combustion could be too hot due to fuel mixture discrepancies (too lean) thus overheating the internal combustion process which will overheat coolant,
e) engine cooling system leak causing the system not to seal thus restricting the pressurised coolant circulatory system (the system needs to be pressurised for effective circulation as well as raising the boiling point of coolant (under pressure water would boil at 110 degrees Celcius instead of 90 degrees Celcius).
Hope you find the problem soon as overheating is detremental to the engine and all integrate parts associated therewith.
Jun 04, 2014 | Air Conditioning and Heat for GMC Terrain
My True Refrigerator T-72 is not working. The compressor runs for about 3 seconds and shuts downn.
Supco has a three in one start kit that can help the compressor to run longer. Although the Freon circulatory system may be clogged and the compressor is overheating internally tripping the thermal overload.
Apr 20, 2013 | True Refrigerators
Difference between organcells and organsystem
If by "organcells" you mean "cell organ", a cell organ a specialized part of a cell, like the nucleus or membrane.
An organ system is a group of organs that work together to perform a certain task. Examples of organ systems:
  1. circulatory system (heart, lungs, blood vessels, etc.)
  2. digestive system (esophagus, stomach, liver gall bladder, etc.)
  3. nervous system (brain, spinal cord, etc.)
Oct 14, 2012 |
The fan in the central unit and the circulatory fan is working but the air blown in the is at 82 deg F and the thermostat is set at 77. The central air unit is running continuously for 6-7hrs now. I dont...
this could be a couple thing . Low Charge, Noncondesable in the system . Or a pulgged coil or thh compressor valves are leaking by . my first guees would be low cahrge . you will have to have guages to check it . You might want to calla tech to look at it though.. I just think you have a small leak .. let me know Jon
Jul 26, 2011 | Heating & Cooling
What is circulatory system???
The circulatory system carries blood throughout the body in a human. Heart, veins, arteries, etc.
If you are referring to a car, I would say you have the wrong term. Perhaps you are referring to the cooling system which CIRCULATES coolant through the engine. Comprised of the radiator, water pump, thermostat, various tubes and hoses, it carries antifreeze/coolant through channels in the engine to keep it at a constant temperature to avoid overheating/meltdown of metal components due the high temperatures produced by the combustion of the fuel in the cylinders.
Please vote if this helped! Thanks, Mike
Jun 12, 2011 | 1995 Chrysler Cirrus
2005 Honda Civic No heat at idle but have heat while driving. not water pump and just replaced head gasket
sounds like a circulatory problem. at the back of your engine compartment there should be two pipes connecting your matrix to your water system. it used to be common practise that when your matrix went to just connect them together and bypass as the dashboard has to come out to repair.
Feb 24, 2009 | 2005 Honda Civic
Computers & Internet Logo
26 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
