Question about Bosch Saws
Bosch JS470E Scroll saw will not hold the blade
rowdy45176
  • 2176 Answers
SOURCE: Changing blade on Dremel scroll saw
I would suggest calling Dremel direct at 1-800-437-3635 and asking for tech help. You might also try their website at Dremel.com, but I have been there and you need to know the exact model number. Let me know and I will dig deeper.
Posted on Jan 17, 2009
  • 3 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
SOURCE: Need manual and lower blade support for the Hawk 216 scroll saw
I can send you a pdf of the manual. Email me at david.lowrance@tx.rr.com
Posted on May 26, 2009
rowdy45176
  • 2176 Answers
SOURCE: after changing the blade on a bosch 1587VS jig saw
I would recheck the installation of the blade and the tightness. If still a problem there is a spring under the lever that might have broke (they tend to do that) and is jamming the spindle. Let me know and I will help you with the breakdown for this tool
Posted on Jul 26, 2009
rowdy45176
  • 2176 Answers
SOURCE: change blade 1587 Bosch avs
are you using the "T" shank blades and also are you loosening the spindle enough to allow the blade to turn, sometimes you have to push up a little to turn it and also pull away from the roller guide. Let me know and also there is a TINY spring in the top of the spindle that has a nasty habit of breaking and winding around itself not allowing proper operation.
Posted on Oct 10, 2009
A bosch PST 54PE jigsaw...the blade falls out when in use
If it works like mine, you need a long, thin screw driver (flat) to tighten a screw that holds the blade. The screwdriver goes in, in line with the blade, on the opposite side.
Jun 12, 2017 | Bosch Saws
I keep getting these BOSCH ss5-115pl scroll saw blades that say they are 11.5 TPI. In reality they are closer to 6 TPI. Am i missing something
put the blade next to ruler and count the number of teeth in the inch measurement
with 6 tpi blade there would be a tooth every 3/32 nch
Sep 21, 2015 | Bosch Saws
Which way do i turn the nut to loosten the blade on a bosch gcm 800s compound saw?
I can't find a Bosch model GCM800 saw in their library but regardless; all arbor nuts, bolts, etc. that hold on blades will loosen if you turn them in the same direction the blade spins when cutting. This makes them self tightening so the blade won't come off while in use.
Feb 26, 2012 | Saws
How the h... do i cabnge the blade on the bosch 1582 cutter ??
I am assuming you are asking because you have a CLIC system.
Bosch uses a tool-less blade changing system for its jigsaws that it calls "Clic." The system makes changing blades fast and simple. With the simple blade changing you get with the Bosch jigsaws, it is no problem to change out a dull blade.
REMEMBER: SAFETY FIRST LAST AND ALWAYS!!!
Make sure the saw is unplugged or the battery is removed.
If you have a blade in there:
Hold the saw over a work bench and push the ejector lever to the center of the front of the saw. There is a center stop; you will feel it. The blade will eject and fall out
Insert the new saw blade into the plunger until it latches into place. The teeth should face toward the front of the saw. The back of the blade should rest in the groove of the guide roller. The plunger and the guide roller are between the body of the saw and the plate
If the blade will not go into the plunger, check the positioning of the slots in the blade. They should be at the top. Push the ejector lever and try again.
Give the blade a yank to check that it is firmly seated. Plug the saw back in or replace the battery and proceed with the cut
Use protective gloves when handling blades. They can be sharp and can be HOT.
I hope this helps
Please rate FIXYA
Thanks
Charly
May 20, 2011 | Garden
Scroll saw problems
sand your #45 #47 and make them rough. They seem to wear down smooth and don't hold.Make sure both meet in the middle do they are meeting the blade both sides the same
Jun 10, 2010 | Dewalt & Variable Scroll Saw
My Bosch 4000 blade will not go down any farther than an inch above the top of the table.I have checked and cleaned all the gear area and can see nothing that is causing it .
First of all, love the saw. As good as portables can be, the 4000 is really great.
Now, just remedied the blade height adjustment problem, here is how:
Unplug saw.
Removed blade....not easy when you cannot raise the blade, flip the saw upside down and remove the plastic shield, turn saw upright and remove blade.
Used my compressor with blower attachment and blasted all of the dust out of the gears and screw rods with saw upright and upside down, bevel saw to 45 degrees to gain more access..
Sprayed quite liberally with silicone spray lube and gently worked blade height adjustment, adding more lube, cranking wheel, more lube....blade adjustment now works like the day I bought the saw.
DO NOT USE WD40 or the like. This will just attract more dirt in a very short amount of time.
We'll see how the silicone spray holds up.
Good luck,
RjW
Jan 24, 2010 | Bosch Electric Table Saws
I have borrowed a Makita SJ401 scroll saw. How do
Scroll saws generally have to be loosened in two spots. One spot is above the blade near the tip of the arm. The other is generally below the plate. Most scroll saws come with a special tool that has an allen wrench type end accompanied by a round peg that is inserted just above or below the spot for the allen wrench.This peg type end helps to hold the tool in place and keeps the saw arm from moving around. The other end of the tool has a handle.
Hope this helps.
Nov 06, 2009 | Plumbing
How do i change the blade on a bosch 3912 chop saw
Push the saw down and manually hold the guard while it is the retracted position and let up on saw while holding guard,you should
be able to put in wrench and loosen bolt.
Apr 09, 2009 | Bosch 3912 12 Inch Compound Miter Saw,...
Rs20 bosch case falling apart
If you loosen the screws at the end of the saw that hold the boot on you can carefully snip the the rubber around the holes. This will alow you to remove the boot without dismantling the front of the saw. The boot is glued and they are sometimes difficult to remove.You can carefully take a flat blade screwdriver to peal the boot off and re-use it. Hope this helps
Apr 08, 2009 | Bosch Saws
Saws Logo
81 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
