Price board AOU30CLX1 fujitsu inverter - Televison & Video
  • 923 Answers
Posted on Apr 26, 2017
Have sound but no picture also trying to connect with Telstra tv and not getting anywhere with installing it. Can’t find a model number, rental house and tv is mounted to wall
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Feb 02, 2018 | Televison & Video
Fujitsu timer lights flashing twice
Serial signal error meaning the outdoor is not talking to the indoor unit. It usually means a faulty inverter / controller board which will have to be replaced. Get a tech to confirm.
Dec 04, 2017 | Fujitsu Heating & Cooling
Timer flash two times
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other assistance check us out online at Boca AC Service we are always happy to lend a helping hand.
May 28, 2016 | Fujitsu 30,000 Btu/h 17 Seer Single-Zone...
Fix serial signal fujitsu inverter asya09lcc
If it is serial signal reverse, the outdoor controller board has a problem. If it is serial signal forward, the indoor board has the problem. First check the the interconnect wiring is ok. If it is, one of the boards will need to be replaced and it is most likely the outdoor board (in my experience)
Feb 20, 2015 | Fujitsu Heating & Cooling
What is the hourly labor rate 2 install this unit
Trades will be very reluctant to give you an hourly rate on split system install as this would deplete the profitability. It depends on the installation, a simple back to back install would take around 3 hours with electrical connection to switchboard. It also depends on brick or fibro walls. Most installations are around 500 Aus dollars total price with the longest time frame of around 4 hours
Jun 10, 2014 | Fujitsu "AOU30CLX1 30,700 BTU Halcyon...
The screen of the laptop is not clear, it so dark but the operating system is ok
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | Fujitsu Computers & Internet
Fujitsu Amilo Pi 1505 25-03-2010 I have a Fujitsu Amilo Pi 1505 Laptop. The screen goes black when viewed at normal angle, when lowered at 45 degrees it comes on. We opened bottom cover and removed the...
With so many questions that really relate to your dexterity and skills! Who can best answer your questions! Yea that person in the bathroom mirror is the only one that will show the fortitude and trail blaze the way. Then boast of their success!
Mar 25, 2010 | Fujitsu AMILO Pro V1000 Notebook
Only can see partial screen not bright enough on ST5112 model
More than likely it is a bad inverter board, I've worked on lots of these units and the majority of the issue with the dark screen is the inverter board.
Nov 06, 2009 | Fujitsu Stylistic ST5112 Tablet PC
I have a Fujitsu Siemens Lifebook s7020 with no backlight. The display is showing everything but it's hard to see because there's no backlight. Everything is also fine with an external screen. I have a...
The Inverter board must be tested and eventually replaced. The inverter is the small board located at the base of display. This is connected to one side to the backlight lamp, to which supplies AC high voltage, and on the other side to motherboard, where receives DC voltage.
Inverter contacts to otherboard and to lamp must be tested , using a multimeter to read volts. The inverter is an AC board, and for safety reason the test must be done by a trained repairer.
If the inverter is OK check the contacts to motherboard and wiring harness to motherboard..
Also ensure that light is not just dimmer because energy save mode is on, or because the laptop is running on batteries.
Sep 07, 2009 | Fujitsu Siemens LifeBook S7020 Notebook
Televison & Video Logo
Top Televison & Video Experts
