Question about Thermador Kitchen Ranges
Thermador rdf30rs dual fuel oven range. The oven turns off when the gas burners are turned on. Any thoughts? Fuse? Incorrect wiring? 220 wired to oven
  • 1314 Answers
SOURCE: Thermador oven/broiler turns off after 5-8 seconds
two things come to mind a faulty safty valve thats the device that the ignighters connect to the other maybe trash stopping the screen on the pressure regulater are any codes displayed on the clock
Posted on Jan 30, 2008
SOURCE: 36 inch range gas not flowing to both burners
I am having the same problem with my oven. One burner comes lights on just one side. Then the second one comes on. Just one side. After a while both side get lit. My concern is unburnt fuel coming out of the oven. Going to trying taking the burner out and cleaning the ports
Posted on Sep 21, 2008
Kgt1962
  • 59 Answers
SOURCE: Viking dual fuel range wiring
You will need a neutral, ground and 2 wires carrying 120V each
Posted on Mar 11, 2009
  • 2876 Answers
SOURCE: Several Gas Burner Igniters spark every 5 seconds
hi could be a short on the ignition switch of the spark box is stuck in the repeat mode disconnet power and see if this helps
Posted on Feb 09, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have a 6 burner,
Welcome to FixYa.
Based on the info you've provided in your post, specifically "The left-front burner (extra-low burner) doesn\'t spark and its gas doesn\'t turn on."
...I suspect you've got a faulty potentiometer ( burner switch for Xtra lo burners). Especially since you've stated the other burners are all OK, that pretty much rules out the simmer control and ignition module.
This is what I'm referring to...
Thus if it fails no current flows and the gas coil won't open and the ignitor won't spark.
Replacing the part can be fairly involved as it requires removing the front control panel of the range, you may want to call a pro, If not let me know and I'll try to assist you in any manner I can going forward.
I also have a service manual for most of the professional ranges from Thermador, even if not exactly like yours the operation and disassembly/service will be the same. I could only provide that via email though so you'd need to post an email address, your call.
I'll watch for your post and we can go from there. Thank's for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Mar 22, 2011
I tried turning the main oven on and it didn't heat up and had gas odor. Side oven and burners were working fine. Next day, tried again and it worked no problem. Next day, same issue.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 16, 2011 | Thermador PD486GEBS Stainless Steel Dual...
Viking model vdsc4874gss small oven works fine large oven element on bottom only gets hot in cleaniong mode, fan comes on when dial is turned to convection but no heat power is on light works
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Oct 18, 2010 | Viking 48" 6 Burner, Grill Professional...
Thermador RDSS30 Cooktop works fine. Oven will not turn on. Any button pushed says ''OFF''
My Thermador CT 127 Convection Oven will not turn on. Lights work, convection fan works, oven will not heat.
Jun 06, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Thermador model RDF30RS burners won't light
Hi, there are two small circuit boards on those burner controls. They are called potentiometers. There was probably a boil over or spill at some point. They are notorious for failing. Hope that helps.
May 04, 2017 | Kitchen Ranges
Dec 27, 2008 | Viking 48" 6 Burner, Grill Professional...
Oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Oct 19, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Sep 18, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
Kitchen Ranges Logo
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
